Kenwood KMR-D362BT install ?
Old Mar 17, 2016 | 12:49 PM
Abaton6's Avatar
Default Kenwood KMR-D362BT install ?
I got this head unit on the advice of a few folks here. I have two questions regarding installation: 1. The antenna connection is not the same. Is there an adapter available for this? 2. The stock plug does not fit the Kenwood. Is there an adapter for this, or did you cut and splice all the wires? I'm looking forward to using this. The stock head unit skips too easily. Thanx in advance for any assistance.
Old Mar 17, 2016 | 12:56 PM
Default Re: Kenwood KMR-D362BT install ?
The sticky on this install will show you the parts you need, also the wire that has to be moved.
The nav radio comes with the correct antenna fitting.
Old Mar 17, 2016 | 05:51 PM
Abaton6's Avatar
Thanx for the link. It didn't come up in my search because mine is a D36, while the link is for the D56. I think is is close enough though.
Old Mar 17, 2016 | 11:57 PM
I did not know it was different looked like my number so .........
Probably similar.
Old Jun 1, 2016 | 11:13 PM
MRED's Avatar
I just installed a kenwood 998 excelon into my 2006 roadster.
Call crutch field an they will sell you the tool to insert into lower part of unit to remove. Also the antenna adapter. An connectors to attach wires
I was done in an hour
Old Oct 24, 2020 | 11:19 AM
Katandb's Avatar
Did you separate out the four channels at the amplifier?
Katiejoe2005
Mar 17, 2016 05:31 AM
Dgiomatch1
Mar 5, 2016 02:33 AM
daniel miranda
Mar 4, 2016 07:08 AM
Mr. Max
21
Feb 25, 2016 06:35 PM
WindRestrictor
Feb 24, 2016 09:35 PM
