Dash lights needing replacement
Old Oct 16, 2021 | 11:02 PM
GeorgeHirata's Avatar
Default Dash lights needing replacement
Hi guys,
Hoping to get details on how I can change my dash lights as some of the dials on the right half of the dash are hard to see due to suspected blown bulbs behind the dash.
Any links to videos and links to part numbers would be really appreciated.
Thank you.
Old Oct 16, 2021 | 11:27 PM
Ronman's Avatar
Default Re: Dash lights needing replacement
Originally Posted by GeorgeHirata
Hi guys,
Thank you.
It is very common for one of two wedge bulbs to burn out behind the cluster.
You need to drop the lower part of the dash. Pull the steering wheel forward as much as possible. Then it is not easy to remove the cluster bezel and even harder to put it back.
There are two large wedge bulbs behind the cluster and then several small ones. If you are going to take everything apart then it is best to change all the bulbs but make sure you take a picture of behind the cluster before you remove them because not all the sockets have bulbs.
Part numbers: Mercedes 0015445594 x 2 (T10 12v/2w) Jahn makes a cheaper version but they don't seem to last as long.
Mercedes # 00000000816764 or Sylvania 2452MFX6 (much cheaper and they are the OEM) x 24.
This Youtube video talking about the skreem kind of shows you how to remove the cluster bezel and cluster itself.
Here is a thread on the forum showing the cluster in detail but use my part numbers for the bulbs. https://www.crossfireforum.org/forum...ght-bulbs.html
Old Oct 17, 2021 | 12:09 AM
Thank you so much for the detailed share!
That's awesome!
Thank you!
Old Oct 17, 2021 | 01:17 AM
Ronman's Avatar
That's awesome!
Thank you!
You are very welcome. Good luck.
soulintent
Feb 19, 2013 10:35 PM
Tee
Nov 14, 2011 05:20 AM
CrossfireTom
Mar 6, 2010 07:37 PM
kinkee
May 30, 2007 08:13 PM
Robzack
Oct 18, 2006 07:07 PM
