Australia Serving Australia.
rear track
Old Dec 16, 2014 | 03:51 AM
saltiga's Avatar
Default rear track
Could any kind crossfire owner measure the rear wheel track on their crossfire? Why do I want this measurement when its in the owners manual as 1502mm. Reason, my car is fitted with 20 inch wheels with a 35mm offset on all wheels, the front offset is ok as it is 35mm, the rear is 22mm , so I should have a rear wheel track of 1476 but I don't, I have 1460mm, this in Australia is an un-road worthy vehicle. (does not comply with Australian design rule) So why is this so?? is the owners manual miss printed? has the vehicle been tampered with? Ah just fit a spacer to make up the discrepancy, again it does not comply with ADRs and if discovered no insurance will be due , the vehicle would be taken off the road and a lengthy police check would follow ( the track at 1476does comply with ADR) thanks Saltiga
Old Dec 16, 2014 | 08:40 PM
+fireamx's Avatar
Default Re: rear track
According to Magazine road tests for the Crossfire,
Front track: 58.3"
Rear track: 58.2"
Surprisingly, the 2003 SLK (using skinnier wheels and tires),
Front track: 58.6"
Rear track: 58.5"
Old Dec 18, 2014 | 12:21 AM
saltiga's Avatar
My owners manual on page 219 , front track 58.8in (1493mm), rear track, 59.1in (1502mm), my actual measurement for the front is 58.6in ( 1488mm) probably add another 1/8in (3mm) for toe in, this is reasonably good and is very close to the manual. The rear with 22mm offset is 58.5 (1486mm) , 57.5in (1460mm) with35mm offset. What does other owners manual give? Is it usual that the same vehicle can vary this much? Saltiga
blackpepper
Dec 18, 2021 06:17 PM
2005 Ragtop
Oct 3, 2015 03:01 PM
Oct 1, 2015 01:42 AM
Billto
Sep 28, 2015 12:05 PM
