Question
I just spent $400 for an old set of exterior windshield trim/molding/garnish. Since they come off so easily and no one makes an aftermarket version, you are limited on your replacement options. I would love to see someone make these. Stainless steel would be nice, but anything will be great.
BeekeeperRob, we do sell replacements for the whole set. We do a reproduction upper centerpiece that we sell with refurbished side piece so the entire set matches. We also sell the Stainless overlays, but they'll only work if you're not missing any of the original pieces. Send us a message if you need some help with something in particular and we'll do what we can to help!
The problem is that they get damaged and or not put on correctly, it is not the design.
OneHundred80, that very well may be. Most people who purchase replacements say that one day they come out and notice that its gone or that it blew off while driving. It is a good point to make sure that if it is removed for any reason to be sure it is firmly reattached and that all clips are engaged before hitting the highway. Thanks for the input!
Velociabstract had a post with photos of when he lost or nearly lost the top trim and the photos showed that the double-sided tape had separated from the clip which had been stuck to the upper trim. The trim clips remained attached to the mating clip which is riveted to the car. The same basic principle applies to the top and side trim.
Some tape was still adhering to the trim and some to the clip, the tape appeared thinner than the regular 3M tape. Maybe this can be obtained from a body shop.
I think that 3M VHB double-sided tape is probably the best tape to use, it comes in various thicknesses and the normal 3M double-sided tape which has a foam core is too thick and will not stand up to the harsh conditions.
We recommend 3M Body weld to hold the clips on. Its by far the strongest that we've found. Its a little difficult to work with as its a two part epoxy style adhesive and it needs to have a certain clamping force applied to make it the proper thickness, but it dries to what can only be equated to as hard as a weld. We can get the part number for the material as well as the gun if anyone is interested in it.
I went to a windshield shop and bought a tube of windshield urethane, used coarse sandpaper on the clips and bottom of the trim where clues go, to better adhere.
for applications with 2 different properties like the plastic and metal that shrink and expand differently at increasing and decreasing temps, to have a good adhesive that can give and move.
I removed and repainted (silver) my windshield trim recently. I found a couple clips loose once I got them off, which must have happened when a windshield was replaced a few years ago. I took the loose clips and used JBWeld epoxy on them. Used it liberally and then clamped each clip to the piece overnight. Also put a bead of epoxy around the remaining clips for future protection when removal may be required. The trim is a little tricky to remove and if not done properly you can loosen the clips from the trim. JB Weld will never give up its grip!
Speedy and Johnny both very good ideas. Personally we're not big fans of the JB weld, but the window weld will probably hold on far longer than anything else plus stays a bit pliable. Both good ideas thanks for sharing!
cudaman
Jun 2, 2017 09:48 AM
ala_xfire
Crossfire Events and Meets
Nov 7, 2016 02:27 PM
danielalexander81
Oct 16, 2016 03:11 AM
Firstpoet
Oct 2, 2016 11:51 AM
