"rear brake clunking" ???
Old May 3, 2006 | 12:47 AM
xfire1's Avatar
Question "rear brake clunking" ???
has anyone noticed at times the rear brake (mine is at the passenger rear) clunks when at a stop. it happens when the brake is depressed and when i go to release it. happening mostly on rainy or very humid days...
j
Old May 3, 2006 | 04:08 AM
HDDP's Avatar
Default Re: "rear brake clunking" ????
j
Check that your rear calipers are bolted down tightly and that the pads are seated correctly. Also inspect the control arm, sway bar and bushings. sounds like you may have a loose part that is being torqued when the brakes are applied.
My guess is the caliper...
Old May 3, 2006 | 09:41 AM
xfire1's Avatar
Darn you're good ... i didn't see your message until now, @ 7:30 am had my XF on the lift/ rear tires off and on the passenger side... we noticed the whole rear brake assembly could be moved a (nano ) fraction of an inch...
tightened it up and thus far on my short ride back home... no clunking...
Thanx
PNA
Nov 12, 2020 04:44 PM
xfireohio
Jul 20, 2020 12:03 AM
xfClifford
27
Nov 10, 2015 10:08 PM
sittininthesun
Aug 24, 2015 10:47 AM
Jerrysrt6
Jul 24, 2015 09:15 PM
