Pedals
Old May 18, 2006 | 04:02 PM
squat6's Avatar
Default Pedals
Has anyone replaced the pedals on their crossfire? I have a base and want to install a set of Sparco Stripes and am wondering which one's to order. There is the standard set and the long version which includes the longer accelerator pedal.
Old May 18, 2006 | 05:19 PM
HDDP's Avatar
Default Re: Pedals
You will need to do some creative installation on them. I would link to the photos I had in the gallery, but after the software update many photos disappeared.
Old Jun 25, 2008 | 03:35 AM
psuperti's Avatar
Default Re: Pedals
I got the sparco pedals ready but I don't have a clue how to replace them. Can someone tell me how they come off?
Old Jun 25, 2008 | 06:14 AM
ZAHANMA's Avatar
Default Re: Pedals
if you check out this thread: https://www.crossfireforum.org/forum...tle+body+woody
waldig looks as though he removed the pedal...though i must admit only the pictures are worth much for your application...other than that I am about as clueless as everyone else. which is a shame, because I wouldn't mind doing a pedal changeout.
Old Jun 28, 2008 | 06:16 PM
rekcah's Avatar
Default Re: Pedals
Removal
1. Disconnect the negative battery cable.
2. Remove the accelerator pedal upper nut (pic2)
3. Remove the lower accelerator nut cover and the nut (pic3)
4. Lift the accelerator pedal off of the welded stud and out of the bracket.
5. Disconnect the accelerator pedal harness connector form the accelerator pedal.
Installation
1. Connect the accelerator pedal harness connector.
2. Slide the accelerator pedal into the bracket and onto the welded stud.
3. Install the accelerator pedal lower nut. Tighten to 15N.m(11ft.lbs)
4. Install the plastic nut cover
5. Install the accelerator pedal upper net. Tighten to 15N.m(11ft.lbs)
6. Connect the negative battery cable
Old Jun 29, 2008 | 07:04 AM
psuperti's Avatar
Default Re: Pedals
Thanks again for the help.
SparkieSRT6
Jan 11, 2016 10:49 PM
xfClifford
27
Nov 10, 2015 10:08 PM
velociabstract
15
Sep 7, 2015 03:43 PM
Blackktieguy
Aug 21, 2015 01:05 PM
WindRestrictor
Jun 1, 2015 02:31 PM
