Headlight replacement - HELP
Old Aug 3, 2006 | 11:56 AM
Rajunz's Avatar
Default Headlight replacement - HELP
I need to replace a headlight bulb on my wife's coupe. I removed the dust cover, then tried to unplug the harness. For the life of me I could not get the harness unplugged from the old bulb, and I don't want to break it. There's not much room to fit my hand in there, but I could not find a clip on the harness. Is there a clip to release the harness from the bulb? If so what do I look for.
Thanks,
- Lance
Old Aug 3, 2006 | 12:05 PM
danimal's Avatar
Default Re: Headlight replacement - HELP
I don't believe the harness unplugs there...just twist the bulb holder about a quarter turn to the left and it should come right out.
Old Aug 3, 2006 | 12:09 PM
Rajunz's Avatar
No, the bulb is held in place with a chrome clip. The manual says to remove the weather cover, then unplug the harness, then remove the clip and the bulb will come out. However, the manual does not tell how to remove the harness (Go figure)...
Old Aug 3, 2006 | 12:22 PM
danimal's Avatar
Hmmm...okay. I'm not real sure then. I assumed they would be like the turn signal bulbs, but obviously not. Sorry for the mis-information. Good luck...and let us know when you figure it out.
Old Aug 3, 2006 | 06:05 PM
BlackEagle's Avatar
Just replaced mine last week remove dust cover and pull harness hard or with pliers straight out.
Old Aug 3, 2006 | 06:11 PM
Rajunz's Avatar
Thanks alot. I went to the dealer at lunch and talked with a technician. He showed me how to pull the bulb out with the harness still attached, then it was much easier to unplug it outside of the socket. Install a new bulb, put the retainer back on, then plug the harness back in.
I just wanted to be sure that there was not a clip holding it because I didn't want to pull too hard and break it. It takes a lot of force to unplug it, that's for sure.
Old Nov 29, 2006 | 10:47 PM
WingMan's Avatar
A good thread, but what I'd pay to know how to pull the bulb and harness out together...
Actually, I'll let you know what I'll pay. As I can't get the harness off the passenger-side low beam (look at the lack of clearance!), I'll be taking this in to the dealership in the next day or two. I can't stand the thought of paying to replace a bulb, but there you go.
Old Nov 30, 2006 | 11:53 AM
Rajunz's Avatar
You take the ring clip off of the bulb and pull like hell. They are sort of stuck in there, but nothing else is holding them in, it will eventually come out. Once it comes out it is a lot easier to pull the harness off.
maxcichon
Jul 8, 2016 08:28 AM
gp1200x
Dec 6, 2015 12:59 PM
Charles Moore
Aug 1, 2015 02:35 PM
Charles Moore
Aug 1, 2015 02:33 PM
LINO C
Jul 31, 2015 10:03 PM
