Neon Light Wiring
Old Mar 24, 2007 | 03:11 PM
nitro4's Avatar
Default Neon Light Wiring
http://cgi.ebay.ca/BEATS-TO-MUSIC-2-...QQcmdZViewItem
Those are the neons I have, except for both of mine connect to the same music sensor. I cut off the cigarette lighter adapter and separated the wires and tried to attach them around a fuse (found under the hood) for the cigarette lighter... but they wouldn't turn on. Any ideas? I also touched the wires to the ends of the car batter and they wouldn't turn on...
Old Mar 24, 2007 | 06:47 PM
stryfox's Avatar
Default Re: Neon Light Wiring
If you hooked them up directly to the battery and they won't turn on they are no good.
Unless there is more to the wiring on them.
Can you provide more info on the music sensor circuit?
Did they work plugged into the lighter?
Old Mar 24, 2007 | 06:56 PM
nitro4's Avatar
when i reattach the wiring to the lighter plug-in, they DO in fact work.
Old Mar 24, 2007 | 07:02 PM
stryfox's Avatar
Is the transformer in the plug?
If it is you will need to get creative.
If it is not you are not doing something right
On a lighter socket the center nipple is + and the outer is ground.
Hope this helps.
A local shop can find an appropriate + hot wire for you.
Wrapping around a fuse is not a good move on electronic controlled cars.
I am not talking down to you I just don't know your experience level.
Let us know how it goes.
Hoppy
Dec 7, 2018 07:36 AM
jhansen
21
Feb 15, 2017 04:26 PM
northwest_crossfire
May 30, 2016 05:19 PM
gp1200x
Dec 6, 2015 12:59 PM
axnguyen
Jul 21, 2015 11:41 AM
