Heated washer fluid?
Old Apr 7, 2007 | 03:40 AM
Mediacritic's Avatar
Default Heated washer fluid?
I read somewhere that Xfires spray heated windshield washer fluid. Anyone know if it's true? I can't find much info on it either way.
Old Apr 7, 2007 | 07:17 AM
bobs's Avatar
Default Re: Heated washer fluid?
The mirrors are heated, the fluid isn't.
Old Apr 7, 2007 | 09:10 AM
acrispy1's Avatar
I also heard the washer fluid was heated, i'm not sure if i read it here.
Old Apr 7, 2007 | 09:12 AM
andrew's Avatar
-C-I-C-C-I Associate Member
~ on some cars the nossle(s) are heated... but the fluid isn't on the crossfire.
you could add it thou...
http://www.windshieldwiperheaters.com/
Old Apr 7, 2007 | 09:20 AM
acrispy1's Avatar
Andrew some cars? Was it on the '04 and later dropped or added later?
I did read it here... https://www.crossfireforum.org/forum...d+washer+fluid
Old Apr 7, 2007 | 09:27 AM
andrew's Avatar
i checked my '04 window sticker... and it states...
~ rear window defroster
~ power heated foldaway mirrors
but nothing in regard to heated fliud...
Old Apr 7, 2007 | 09:39 AM
andrew's Avatar
'hot shot' is now installed on some cars from the factory...
http://www.theautochannel.com/news/2...24/141203.html
http://www.theautochannel.com/news/2...28/020060.html
Old Apr 7, 2007 | 09:51 AM
GatorLCA's Avatar
Power heated fold away mirrors??? Are they always heated and I've tried to fold them away and had no luck cause I don't want to break them.
Old Apr 7, 2007 | 10:04 AM
andrew's Avatar
the heating of the mirrors is activated by using the cars rear defroster button...
here are pics of the mirrors folded in both directions... (grab hold with both hands and twist the mirror... it will release)...
after a washing... i fold them in so the water drips out from behind the glass.
Old Apr 7, 2007 | 12:07 PM
MI1XFIRE's Avatar
I heard of people drilling a small drain hole at the bottom of the mirror to prevent this from happening, but your recommendation is much better. Thanks Mr Clean.
Old Apr 26, 2007 | 04:06 AM
bobs's Avatar
Bumping this thread back to the top...
Apparently the Crossfire DOES have heated fluid and nozzles (my '04 coupe, anyway). I was poking around under the hood and opened the main fuse box (driver's side, near the firewall). The little card inside clearly labeled fuse #12 as for washer fluid and nozzle heaters! I'm going to look closer tomorrow and see if the heaters are actually there or in the same status as the rear fog light on US models...
Old Apr 26, 2007 | 04:24 AM
bigpapapuff's Avatar
Talking Re: Heated washer fluid?
Heated washer fluid? Crossfire, no. SLK Mercedes, yes. Seems we got the short end of the stick on that one!
Old Apr 26, 2007 | 10:33 AM
bobs's Avatar
Kinda what I thought too, but there's actually a fuse in there so it's got me wondering. It's not like DC to add expensive fuses for no good reason so I'm going to do a little fishing...
Old Jun 17, 2007 | 12:40 AM
04Fire's Avatar
Just thought I'd share...
Old Jun 17, 2007 | 02:38 AM
Got me wondering more too, so I did the research in the service manual. Fuse 12 in the underhood accessory fuse block is infact a 10 amp fuse, but in the electrical diagram in the service manual, it shows that it has a fuse, but it's not used for anything. I also went through the narrative for the wiper system in the service manual and it makes no mention of heated wipers.
It is confusing why they would put a fuse in and then label it for heated wipers when we don't have heated wipers. Also none of the pictures of the wiper nozzles show wires going to them indicating they would have a heater in them, plus the washer fluid bottle don't have a heater in it. It really is confusing. Makes ya want to have a nice cold brew and ponder it a while longer... Hmmm, think I will!!
Old Jun 17, 2007 | 08:22 AM
andrew's Avatar
~ if it was in fact heated... one would think... when a warm fluid was sprayed/applied on to a cold windshield (winter time) steam would appear (even a slight amount) with the exposed temperature change??
Old Jun 17, 2007 | 09:15 AM
You are right Andrew, and I have never seen the steam on my windows at all.
Old Jun 17, 2007 | 11:22 AM
04Fire's Avatar
Never driven in winter... but that does make sense. Still why is the fuse in there.
Old Jun 17, 2007 | 12:37 PM
I think I have seen just a bit of steam, and I was always surprised how well the washers worked on my icy windshield, which is what prompted my question originally. Hmmm...
Old Jun 17, 2007 | 07:49 PM
midnightman's Avatar
I noticed the fuse for the heated washer fluid right after I got my XF back in October of 2005 while examining just about every little thing during that first week of ownership. I just assumed it was true. Here in South Florida, it really doesn't make much difference either way. The fluid is naturally heated by ambient temperature.
But there is one strange thing I noticed about 04Fire's pic of the fuse panel card from within the fuse box...
Mine looks just as warped and crumpled as his. I was kind of surprised to find it in such condition while the car was otherwise pristine when purchased.
