boot/trunk cover fitting
Old Jun 21, 2007 | 07:44 AM
hodgy's Avatar
Default boot/trunk cover fitting
Hey Guys, i'm over in the UK and have just taken my '04 x-fire in for it's 1st MOT, whilst it was in there I had the 'cracked' wheels caps replaced under extended warrenty for free which i'm very pleased about... but i also requested a startech brochure so i could see how much a boot/trunk cover would be compared to importing one from CTD in Germany - they told me that it would be much cheaper to import.
Fair enough...
But they then went on to tell me that there are no existing fittings to install the cover on (although i have noticed two small 'buttons' in the boot/trunk so does it not attach there?) Anyway, they told me it would take 3 hours at £80.50 an hour for them to fit it!
How easy is it to fix yourself - are they just having a laugh?
Cheers,
Matt
Old Jun 21, 2007 | 08:03 AM
andrew's Avatar
-C-I-C-C-I Associate Member
Default Re: boot/trunk cover fitting
i installed my cargo cover and it took about an hour.
Old Jun 21, 2007 | 08:24 AM
hodgy's Avatar
Bet you didn't charge yourself £80 an hour either ; ) haha.
Was there much drilling etc needed or is it a pretty simple job to do ?
danimal's Avatar
Same here. There are pre-threaded holes in the bulkhead where the cargo cover bolts on. A couple of slits in the carpet following the template and you are there. Easy to install with patience.
Old Jun 21, 2007 | 08:25 AM
hodgy's Avatar
sounds good!
looks like i'll be hanging on to my money and giving it a go myself!
Old Jun 21, 2007 | 02:50 PM
bobs's Avatar
I just installed mine this weekend. It's pretty easy, just take your time and you won't have any problems. Just remember the old axiom of "Measure twice, cut once".
A couple of things to watch out for:
1. The instruction sheet specifies to tighten the nuts that screw on to the bulkhead to 30nm. I almost stripped one of them while tightening it. I would recommend changing the torque to "snug" +- 5nm. The bolts are pretty hefty and will hold the cover easily.
2. Be very precise when you mount & drill the templates for the hooks that go on the back by the hatch. If they're off by even a little bit the screws will be very difficult to line-up.
xfireohio
Jul 20, 2020 12:03 AM
minimayhem
17
Jan 19, 2016 02:10 PM
RiderJC
Sep 7, 2015 11:19 PM
user 8202
Canada
Sep 1, 2015 11:43 AM
MAXIMUM
Aug 4, 2015 11:04 PM
