Annoying... Little Problem
Old Jun 21, 2007 | 05:37 PM
lightningryan's Avatar
Default Annoying... Little Problem
Tried the search and came up with nothing. I pull up to the gas pump and my fuel door is stuck shut and will not open. Im sure it has something to do with the closing mechanism but any advise on how to get it open. It is still stuck shut and after an hour of messing with it I give up.
Thanks in advance guys,
Ryan
Old Jun 21, 2007 | 06:45 PM
midnightman's Avatar
Default Re: Annoying... Little Problem
Make sure you have pressed the door unlock button (either on the key fob or the console) 2 times.
Old Jun 21, 2007 | 06:48 PM
ROCKSTAR's Avatar
Exactly what midnightman said! Don't feel stupid if it was just locked, I've had plenty of xfire blonde moments too. =D
Old Jun 21, 2007 | 06:51 PM
RPM's Avatar
RPM
Moderator
Ryan,
midnightman is correct -
The doors must be unlocked for the fuel door to open.
On the roadsters - the center console is the same way.
Old Jun 21, 2007 | 07:43 PM
GatorLCA's Avatar
It'd be nice if the coupes were the same way, but I guess since it's pretty impossible to fit anything through our window, let alone a body to reach the door unlock on the center console, it doesn't matter so much.
It would be a nice option to have though in the coupe.
Old Jun 21, 2007 | 07:50 PM
Thirteendog's Avatar
I believe if you car is locked and the alarm is armed, hitting your unlock button on the inside of the car will set the alarm off.
Old Jun 21, 2007 | 08:07 PM
patpur's Avatar
Senior Member/Moderator
Agree with all of you unless the pneumatic line to the filler door has broken. that's an issue that scares me. I've already had the line to the rear hatch go and it wouldn't lock. Hopefully that is not the case here and its what everybody else said. Ryan please let us know what it was and don't be embarrassed.
Pat
Old Jun 22, 2007 | 11:41 AM
AMGLover's Avatar
Message Deleted
Old Jun 22, 2007 | 02:53 PM
I had an annoying problem so I got a divorce and bought a Crossfire.
Old Jun 25, 2007 | 12:05 PM
Yea guys, figured it out and it was just locked. It makes total sense to me now but could not figure it out until I hit the unlock button to get inside the car to get the manual and it magically popped open and then at that time I saw the lock. Thanks for all the help guys.
Ryan
Old Jun 25, 2007 | 12:18 PM
xfire2005's Avatar
Ditto!! Maybe we should start a club ?
franklindm
Mar 14, 2020 12:23 PM
eikon
Sep 9, 2019 10:16 PM
Sterling57
Apr 11, 2016 06:11 PM
Steven 4190
Nov 25, 2015 10:12 AM
jimf
Oct 10, 2015 10:22 AM
