Headlight Help!
Old Sep 3, 2007 | 12:10 AM
Cruiser's Avatar
Angry Headlight Help!
As I had posted not long ago, I was having headlights burn out. I do recall when I first got my car, driving on a dark road; the beams were wide and bright. Now after having the last bulb changed, I drove the car last night in the dark, and I had to lean forward, to see if they were even on! When they changed one before I noticed they were not as bright. Are they using the wrong bulbs?
What the heck do I tell the dealer when I take it back? What are they doing wrong? Please help, I can’t drive at night, till it gets fixed.
Thanks!
Old Sep 3, 2007 | 06:41 AM
danimal's Avatar
Default Re: Headlight Help!
It sounds like they are not seated correctly. With the 'big bucks' you are paying them to change a bulb, take it back and ask them to install it properly.
Old Sep 4, 2007 | 08:42 PM
Cruiser's Avatar
If that's what your thinking, there not seated correctly,what would I tell them? Is there a trick to installing them a correct way that I can tell them? Since they must not know anything...
Thanks!
Old Sep 4, 2007 | 10:04 PM
palexfire's Avatar
changed my bulbs myself took 10 min, i used silverstar h7, i noticed a big difference. could be they charge benz price for ford quality???
i didn't even have to aim the lamps or anything, just pulled out popped in that's it.
Old Sep 4, 2007 | 10:06 PM
DanielNTX's Avatar
Replace them with real HID bulbs and notice a bigger difference.
Old Sep 5, 2007 | 08:46 AM
danimal's Avatar
Thanks!
I can only tell you that after replacing mine, it took 2 or 3 times to finally figure out when it was seated correctly. After that, the rest of them were much easier to install. If it is only illuminating a short distance in front of the car then the bulb isn't installed correctly. Good luck.
smfrycruzr
Jul 17, 2023 05:33 PM
srtmodder
Aug 23, 2017 08:28 PM
Franc Rauscher
May 9, 2016 12:04 PM
gp1200x
Dec 6, 2015 12:59 PM
RacerXofFL
Sep 15, 2015 05:00 PM
