Cracked Trans case at 88k
Old Nov 8, 2007 | 01:39 PM
txcross04's Avatar
Default Cracked Trans case at 88k
I need a little direction from the group, my '04 manual transmission xfire with 88k miles has let me down for the first time. I have never had a single issue with the car until this week when it decided to dump transmission dluid all over the place. Long story short...I took it to the dealership and the transmission case is cracked. The estimate is $4,800, if anyone can poiint me in the direction of a used transmission or used case (since my internals are fine) I would greatly appreciate it.
Old Nov 8, 2007 | 01:43 PM
RPM's Avatar
RPM
Moderator
Default Re: Cracked Trans case at 88k
Here is an auto trans on ebay:
http://cgi.ebay.com/ebaymotors/04-05...spagenameZWD1V
You might want to contact the seller and ask if he knows where a manual trans is.
Old Nov 8, 2007 | 01:48 PM
Idaho's Avatar
Depending on the where the crack is a good welder might be able to fix it as long as it wasn't a stress related crack and even then maybe. It is not the most desirable option but may be the most economical alternative. I guessing that the damage was road, was it?
Edit:
RPM's post beat mine in, but if I were you I would would go for the one on eBay. Your's could still be fixed at a latter date if needed.
Old Nov 8, 2007 | 02:00 PM
txcross04's Avatar
Idaho & RPM thanks for the advice, I will be calling the ebay seller now. I have no clue where the damage came from and the dealership says they have never seen this on a crossfire. I do a lot of hwy driving, and about a month ago I noticed an occasional drip in the garage, not even a daily drip. Monday I went to have new tires put on and it was like a re-enactment of the Exxon Valdez.
I noticed that zeracer posted that he had a 05 manual for sell back in september, if you know him could yuou please have him contact me regarding this thanks.
Old Nov 8, 2007 | 02:10 PM
jackei's Avatar
Hope you will get it fixed soon.
It happened to me one time on my Ford Taurus, the transmission fluid spilled everywhere as I got off the freeway. I was so lucky that I found out it was just a hose came loose. I reconnected it and added the fluid and keep going (Yes there was an auto shop just one blocks away). Best possible case one can ever had.
Old Nov 8, 2007 | 02:14 PM
txcross04's Avatar
I am very lucky that the spill occured while it was on the lift at discount tire...had I been on the hwy, i can only imagine the damage.
Old Nov 8, 2007 | 03:39 PM
ShawnQ's Avatar
There was a manual trans for $299 on ebay last week from LKQ.
Look in the SRT6 forum for a post called 'no manual SRT' by StaticXfire, I posted the link in there.
SQ
Old Nov 8, 2007 | 04:29 PM
RickZ's Avatar
For Sure check with LKQ they seem to advertise a lot of Crossfire parts... Good Luck.
Old Nov 8, 2007 | 04:34 PM
txcross04's Avatar
Thanks ShawnQ, i sent LKQ a message...its no longer listed.
Old Nov 8, 2007 | 04:54 PM
Mr. F's Avatar
am i the only one who thinks this is an odd coincidence?
Old Nov 8, 2007 | 04:55 PM
RPM's Avatar
RPM
Moderator
Nope, I kind of wondered the same thing. Seems odd, huh.
Old Nov 8, 2007 | 05:09 PM
HDDP's Avatar
You think ?
Mr. F... You seem to know your stuff... I would bet they drove the car onto the lift with one of the offset arms in the center... Perhaps even with the adjustment plate sticking straight-up... And CRUNCH !!!
Old Nov 8, 2007 | 05:14 PM
Mr. F's Avatar
after seeing that pic of the Lotus that was dumped off the lift...it was the first thing i thought of.
txcross04's Avatar
After looking on LKQ I could get a SRT6 engine with 8k miles, and an auto transmission with low miles for about a grand less than the dealer wants for a new transmission.
Also I pulled the car into the bay at Discount...and no crunch.
Old Nov 8, 2007 | 05:15 PM
Mr. F's Avatar
no crunch? i believe that. but you weren't running the lift...THEY were.
and please tell us the conversation didn't go like this:
they said "we didn't do it," and you just said "okay!"
Old Nov 8, 2007 | 05:20 PM
txcross04's Avatar
Ahhhh, I did not think of that. Anyway to prove this, other than it was not dumping fluid prior to that?
Old Nov 8, 2007 | 05:21 PM
Mr. F's Avatar
uh, yeah.
IT WASN'T DUMPING FLUID BEFORE THAT.
you got it back, and it was.
Old Nov 9, 2007 | 07:50 PM
banjoman's Avatar
Is this a somewhat rare but regular occurrence with the Xfire? I also have a Miata NB, and regularly read/troll the Miata forum, but this occurence is none with those, and most Miatas are manual, and driven hard (myself included), including motocross racing.
Old Nov 9, 2007 | 08:32 PM
RPM's Avatar
RPM
Moderator
I have never heard of this issue other than on this thread. There is a somewhat common trans seal issue, but not this.
Old Nov 9, 2007 | 08:58 PM
HDDP's Avatar
True... I'vee been here for a LONG time (in relative terms) and this is the 1st occurance of this...
