Resetting OEM Nav
Old Jan 3, 2008 | 05:34 PM
62thunderbird's Avatar
Default Resetting OEM Nav
Been using the TomTom lately instead of the OEM indash nav. But I noticed today the OEM now has no GPS lock on any of the satellites. There has been no power inturruption and I have the CDs, but I can't re-calibrate the thing. I scoured the instruction manual but had no luck.
It would be nice to have a working nav as a backup, and if it is truely frogged, I might as well get it replaced while its under warranty. Any recommendations?
Old Jan 3, 2008 | 05:41 PM
Default Re: Resetting OEM Nav
Did you follow the reset instructions in the manual?
Old Jan 3, 2008 | 07:08 PM
Is it the triggering Reset section on page 107? Did that today with absolutly no effect. I'll try again tomorrow.
Old Jan 4, 2008 | 05:53 AM
Thom's Avatar
When I had my Crossfire with the Navigation system ~ that happened to me several times. What I did was to insert the Nav CD ~ let it reset itself <a minute or so> then took the Nav CD out and everything worked as normal. Hope that helps. Thom
Old Jan 4, 2008 | 06:11 AM
The manual says to press the #1 and #3 multifunction keys at the same time you press the OPT key. That should reset it. The first two times it did not work. The third time I was in Radio mode insted of Nav mode and the reset worked.
So the Nav's as good as new albeit with 3-year old map info...
Old Jan 4, 2008 | 06:13 AM
beasticles's Avatar
Just throwing an idea out there but could it be the TomTom navigation system is interfering or scrambling the OEM nav system's links to satellites?
Old Jan 4, 2008 | 06:14 AM
Just stay out of those new constructed areas and it works like a charm.
RED DOG
44
Oct 27, 2020 09:00 PM
2005 Ragtop
Oct 3, 2015 03:01 PM
4drturbo
Oct 2, 2015 12:58 PM
paine2907
Oct 2, 2015 10:01 AM
smokey847
Sep 15, 2015 10:47 AM
