1st gear popping
Old Jan 6, 2008 | 08:12 PM
makeithappen's Avatar
Default 1st gear popping
now i have driven two stick cars before i got my crossfire. none have gotten this problem before. every once in awhile i will be at a stop light and push it up into first then i start drivin and right when i get about a roll it pops out of first real hard that almost makes the car jult. i already took it one time to the chrysler dealer and they test drove it and said they found nothing. i am taking it back this weekend again because it is doing it more and maybe this time they will actually find out what is wrong. if anybody has any ideas i would like to know.
Old Jan 6, 2008 | 08:22 PM
Iamfink2's Avatar
Default Re: 1st gear popping
TBS: 9-Mar-04 - 21-002-04 - Manual Trans - First Gear Disengages During Normal Acceleration
Old Jan 6, 2008 | 08:30 PM
where did you find that? and sorry i am really tired. but what does that tell me? sorryy
Old Jan 6, 2008 | 08:33 PM
apkano's Avatar
Life is random...so am I.
Are you sere it's all the way into first gear? I'm not trying to imply you don't know what you're doing.....I just know that mine has done that before, and it was because it wasn't fully engaged into first. I've found that when you just pull it out of a higher gear (4th or higher) and try to go into 1st ......it's a little sticky, almost like there's 2 detents in first gear.
I usually make sure to go into 2nd and then to 1st, sometimes it takes more than one try. If you go from 2nd to 1st a few times you'll find that it slips into 1st a little easier each time.
Old Jan 6, 2008 | 08:37 PM
i would say i am 99 percent sure it is not that. at times it is also hard to get in to first and i have to put it in to second then throw it up in to first.
Old Jan 7, 2008 | 08:53 AM
Maxwell's Avatar
ahh yes, you must have a 2004 model, built in Nov or Dec of 2003. They just need to do the synchro update. been there done that!
to get the dealer do do the work, you must say it is intermitant maybe 1 out of 20 time it happens, then tell them you almost got in a car accident because it popped out of gear while making a turn. Ta da! that will make em jump for you!
Old Jan 7, 2008 | 09:30 AM
haha thats good. thank you and u would be correct its an 04 =)
Old Jan 9, 2008 | 08:32 PM
well i took it into the shop today and they called me tonight and told me i would need to come in and take a ride with the mechanic and proove to him it is happening before he will order the part. WTF. i told them it only happened every once in awhile and showed him the TSB but they still want me to drive with the mechanic? this will be the second time it has been in the shop for this and the first time they drove it then told me they could do nothing. and ideas?
Old Jan 9, 2008 | 09:24 PM
sonoronos's Avatar
They are making you drive? Then start from a stop 1000 times until it happens.
As your name says - Make It Happen!
Old Jan 10, 2008 | 05:58 AM
well its alot easier said then done haha. i am still trying to find a link of when it happens most. and i deffenately will be trying to make it happen haha.
this sucks
Old Jan 10, 2008 | 11:57 AM
Shawnkey's Avatar
look for a beter dealer in your area, chances are they haven't taken the trams out of one, and you don't want to be the guinne pig, do you?
Old Jan 11, 2008 | 08:11 AM
they said "chrysler will not let us do it without knowing something is wrong" ugh. and they say they have a few certified mechanics and then this mechanic told me that there transmission people are better then the crossfire mechanics anyway. i was like mmm hmmmmm. so as the story goes i am sezrching for a better dealership.
jimf
Oct 10, 2015 10:22 AM
rfourt
Sep 25, 2015 01:38 PM
Calitony
Sep 24, 2015 12:53 PM
eatmycrackers
Sep 23, 2015 09:08 AM
PA/XFIRE
Sep 5, 2015 01:25 PM
