Fuel Door
Old Jan 20, 2008 | 04:07 PM
Cruiser's Avatar
Unhappy Fuel Door
My check engine light came on again. So I checked the fuel door, and it will not stay closed. I pressed on the plunger and it came back up, tried to close the door, but it will not latch.
Even when I lock the car, any ideas how to fix it?
Thanks
Old Jan 20, 2008 | 04:48 PM
Shawnkey's Avatar
Default Re: Fuel Door
Your engine light will not come on due to the door being open. If your gas cap is loose or off, then it will. the door will not.
As far as why your CEL is on, could be a couple hundredthings.
Old Jan 20, 2008 | 04:52 PM
Cruiser's Avatar
Andrew had told me when the Engine light came on, to check the fuel door. I did, and after taking the cap off a few times and closing the door, the Engine light went off.
The problem I am having, is that the door will NOT stay closed...any ideas?
Thanks
Old Jan 20, 2008 | 05:00 PM
Shawnkey's Avatar
OK first:
The fuel DOOR will NOT cause an engine light.
The fuel CAP WILL cause an engine light
second:
You probably need the whole housing part# 5099987AA
I would consult your local parts department though.
Old Jan 20, 2008 | 05:01 PM
Aknester's Avatar
Hello, is the doors unlocked when trying to close the door? Make sure they are unlocked because the lock pin would be sticking out and keeping the door frorm closing.
Good Luck,
Allan Nester
Old Jan 20, 2008 | 05:04 PM
Shawnkey's Avatar
Thought to self
***Why is it that when I try to help somebody with a problem I feel like I have to tell them that I am a crossfire tech? ***
Old Jan 20, 2008 | 05:21 PM
Cruiser's Avatar
Talking Re: Fuel Door
OK first:
second:
OK, Shawnkey,
Maybe I wrote it down wrong. Andrew had me check the gas cap, then drive the car a few times, and the engine light went off. Whew!
I will go out a try now what Aknester just mentioned.
And Shawnkey, thanks for your input, it really is appreciated...
Old Jan 20, 2008 | 05:47 PM
former NXMX5's Avatar
Originally Posted by Shawnkey
Thought to self
since when do crossfire techs know anything...
Old Jan 20, 2008 | 06:06 PM
old man's Avatar
are you a crossfire tech
Old Jan 20, 2008 | 06:11 PM
Display_Name's Avatar
(This has nothing to do with the check engine light, but it might explain why the fuel door doesn't close.)
Sometimes the "lanyard" that hooks the gas cap to the car gets twisted up a bit and when not folding down correctly it interferes with the hinge of the fuel door, making it so the fuel door doesn't close down all the way.
Old Jan 20, 2008 | 06:44 PM
woodlands1's Avatar
Shawnkey is.
Old Jan 20, 2008 | 06:47 PM
Cruiser's Avatar
Thanks, I will go out and check that. Hope that does the trick if it lays out of the way of the closing.
Old Jan 20, 2008 | 07:56 PM
Moparrbust's Avatar
Thought to self
Maybe you should put it in your sig.........................
"I am a Crossfire technician...........I MIGHT KNOW WHAT I'M TALKING ABOUT"
something like that might help out a little.
Old Jan 20, 2008 | 08:05 PM
walc's Avatar
Actually, with all the new members, everyday, that isn't a bad idea.
I know that I appreciate Shawnkey sharing his professional knowledge.
Old Jan 20, 2008 | 08:45 PM
cgocifer's Avatar
I had two Crossfire techs working on my car for 2 months for a failed seatbelt not fastened audible alarm. They replaced the instrument cluster, the computer module, the seatbelt switch, and ruined my interior and leather by puncturing and scratching things with tools, and finally gave the car back. Oh, and the audible alarm still doesn't work!
I'm sure shawnkey is better though because he actually has a crossfire.
Old Jan 21, 2008 | 06:13 AM
Crossfireone's Avatar
Shawnkey, thank you for your input to our problems. Don't let all those "I wish I was a tech" people stop you from putting your advice on line for us. Your expertise is apprec.
Crossfireone
Old Jan 21, 2008 | 06:25 AM
walc's Avatar
Crossfireone
I agree 100%.
Old Jan 21, 2008 | 06:55 AM
Thought to self
Just put in your sig: " I am a Crossfire Tech. But, I'm not smarter than a fifth grader."
Old Jan 21, 2008 | 07:09 AM
blackxfire's Avatar
CGocifer,
Where did you bring your car. I need to stay away from them. Was it in NH or MA? You might want to post your bad experience on the New England forum. Don't forget to mention which dealer gave you the crappy service.
Osusannah
Feb 12, 2024 01:49 PM
Valk
Jul 12, 2021 09:49 PM
Mackel
Oct 16, 2015 09:03 AM
Billy22Bob
Sep 28, 2015 08:08 PM
jaesa
Sep 7, 2015 01:50 PM
