Cracked valve stem...
Old Feb 26, 2008 | 04:09 PM
MDicillo's Avatar
Default Cracked valve stem...
Hey everyone...I just found out my valve stem on the rear driver's side is cracked. I took it into the dealer and of course, they didn't have the part in stock...they said they would order it and it should be in tomorrow...the price is $162...my question is, shouldn't this be covered under warranty?
Old Feb 26, 2008 | 04:18 PM
downwardspiral's Avatar
Default Re: Cracked valve stem...
Do you still have the bumper to bumper, it wouldnt be covered under drivetrain
Old Feb 26, 2008 | 04:21 PM
MDicillo's Avatar
It's a 2005 with 28,000 miles on it...so, I'm not sure. I know I got the full extended warranty as well...
Old Feb 27, 2008 | 04:54 AM
spensley's Avatar
The valve stem, which is usually replaced when you get new shoes?
I would seroiusly consider putting in a regular stem without TPS.
Old Feb 27, 2008 | 05:23 AM
PAULW's Avatar
The part number is 5096808AA and list price is $120.00, I would check around because you should be able to buy it under a bill.
Old Feb 27, 2008 | 06:44 AM
MDicillo's Avatar
It seems that this would be covered under my warranty. It's a 2005 with 28,000 miles on it...This is not something that seems like it would just break with wear and tear...it's a valve stem!!! Is there anything I could say to convince the dealership otherwise if this is not covered?
Old Feb 27, 2008 | 07:16 AM
spensley's Avatar
It shouldn't break under normal conditions, but you could have caught it against a curb, car wash may have damaged it, somebody kicked it - I'm just being the service dept. ant the stealership!!!
Old Feb 27, 2008 | 07:40 AM
I believe, if you put a non TPS valve stem on it you will have to disable the fearure so the dash doesn't keep warning you of a low tire. I think you can just remove the fuse ???
syfi
Mar 28, 2026 04:14 PM
Billy22Bob
Sep 26, 2015 10:16 PM
maxcichon
Sep 25, 2015 02:55 PM
tritongreen
Sep 18, 2015 07:32 AM
RacerXofFL
Sep 15, 2015 05:00 PM
