Sprint Booster - Negatives
Old Aug 27, 2008 | 09:55 AM
  #41 (permalink)
PAULW's Avatar
Default Re: Sprint Booster - Negatives
Originally Posted by oxycodone
That is exactly what happens: you're at full throttle at somewhere between 1/2 and 2/3 pedal depression.
I am sorry but we will just have to agree to disagree on this point, everyone has a perception of any event and your perception of this product and my perception of the product are totally opposite and that is ok. I do however believe (my perception) I know when I run out of throttle and it isn't at 1/2 to 2/3. I will however submit this, after reading all the posts on many Sprint Booster threads all but a couple are SB fans and would not take theirs off and in my books that makes it a successful product.
PAULW (aka The CHUMP)
Old Aug 27, 2008 | 10:31 AM
  #42 (permalink)
SRT6nTulsa's Avatar
For your daily driving thrills, the sprint booster is leaps and bounds better than the throttle reset. I would say that a throttle reset does about 10% of the improvement of the sprint booster. With my sprint booster, it is almost impossible to accelerate moderately without practice. Under light pedal movement, it feels like my car has 800 horses. Accidental tire slippage under what "feels like" light throttle is common.
Old Aug 27, 2008 | 10:46 AM
  #43 (permalink)
DesertFox's Avatar
True that! I drove this Toyota Corolla (stock), and when I lightly touch the throttle, I get accidental tire slippage too! It's only got 120 hp, but it feels like 300! Unfortunately, when I add more gas (going from 10% to 80% of the pedal), I don't get anymore power.
Old Aug 27, 2008 | 11:46 AM
  #44 (permalink)
Cal_Cobra's Avatar
From: Brentwood, CA (no not the OJ Simpson Brentwood, the real city of Brentwood in NorCal)
Originally Posted by PAULW
The thing about building a knock off is this, Boulekos Dynamic found a need, did the homework, built and marketed a product that works and actually it is not an unfair price, no other manufacturer has introduced a device for any brand of car to correct drive by wire throttle lag, at least none that I have found.
As an engineer I'm more interested in what exactly makes it tick. I used to build a lot of home brew computer projects, electronic synthesizer projects, etc., so I enjoy the builder/tinkering hobby aspect of electronics. It might well be possible to improve upon the design (manual or otherwise programmed adjustments would be a welcome addition in my book, perhaps you don't want 2/3 throttle equal to WOT, or?).
Food for thought.
Old Aug 27, 2008 | 11:58 AM
  #45 (permalink)
Cal_Cobra's Avatar
Originally Posted by Hairydalek
There’s a thread on this forum which included a report on what the Sprint Booster actually does.
Clicky
The actual PDF can be read here: http://frontiernet.net/~dbipes/sprintbooster/SprintBooster.pdf
Not having had a sprint booster fitted, I can’t agree or disagree with the findings. However, it does appear to “deaden” the last 1/3 of pedal travel, which could be disconcerting (ie the pedal peaks at 2/3 of its usualtravel). My guess is that you could physically stop the pedal where it peaks to give you the “it’s on the floor” feel.
I think I’d rather look to other software mods to up the BHP if I wanted some extra kick (remove the limitations built into the ECU for example). According to this document, Sprint Booster does not improve acceleration, rather it gives the illusion by reducing the point at which the throttle peaks.
Are there any ECU reprograms to "enhance" the drive by wire experience ?
Old Aug 27, 2008 | 12:18 PM
  #46 (permalink)
DesertFox's Avatar
Food for thought.
+1. I thought someone already took it apart? It would be pretty sad if it some transforms the voltage signal, and no more, which is what the paper suggests, but that doesn't jive with the seller's claims of "linearizing" the throttle. Is there anything else it could change besides the actual voltage? maybe the ramp rate of the signal?
Old Aug 27, 2008 | 12:20 PM
  #47 (permalink)
maxcichon's Avatar
I'm pretty sure that's ALL it does. Read my previous post?
Old Aug 27, 2008 | 12:32 PM
  #48 (permalink)
DesertFox's Avatar
Sorry, I read it, and forgot about it. No offense yo you, it's an ADD thing. Thanks for the reminder.
With that in mind, how is it "linearizing" (or linearizing the perception of) the throttle at low inputs? I find that I get too little power, then too much power, at low inputs. Would the SB just make it feel like too much power, then WAY too much power, with the same inputs? I think that's where I'm missing its effect.
Old Aug 27, 2008 | 12:33 PM
  #49 (permalink)
+fireamx's Avatar
Increasing air flow (on both the intake and exhaust) will help. Changing your fuel map to accomodate the increased air flow is much more important.
I was being facetious in my previous post - there are many on this board who have stuck some aluminum tubing on the intake, routed it next to the engine and fitted a cone filter on the end and called it a "Cold Air Intake" - which I personally find hilarious... while that system may get you increased airflow, it certainly won't have a lower temperature than the stock setup.
I agree, being an "aluminum" tube it may even be warmer. But the increased volumn seems to help, even with no other changes.
But to actually gain a cooler air temp, insulation would be needed for sure.
Old Aug 27, 2008 | 12:43 PM
  #50 (permalink)
PAULW's Avatar
Food for thought.
Good questions and thought line. The best products are usually invented by one and a "tinkerer" takes it to the next level and hopefully does so with the approval of the inventor. I have had my ECU remapped and at least the place that did mine could not correct the lag and I have not heard of any that can. I work in the heavy truck business and we have used drive by wire for some time so I understand what all is done by the computer with the information from the TPS, it isn't just throttle control.
Now having said that if we could add an old style throttle linkage and move the TPS from the foot pedal to the engine then the computer and I would both be happy!
Old Aug 27, 2008 | 01:30 PM
  #51 (permalink)
maxcichon's Avatar
Post #42. SRT6Tulsa sums it up pretty well. It does take some getting used to. I really used to be frustrated by the lethargic way it would accelerate, say, from a traffic light. A slow build-up like "The Perfect Storm". Now I want to be the first in line so I don't rear-end the fella' in front of me.
It takes practice, but that's a GOOD thing!
Old Aug 27, 2008 | 06:33 PM
  #52 (permalink)
DesertFox's Avatar
Got it... I'm the other way around... I feel like I don't have enough travel in the pedal, and that, even w/o the SB, the throttle ramps up too quickly with too little input. I don't need a Sprint Booster... I need a Sprint Buster...
Old Aug 27, 2008 | 07:13 PM
  #53 (permalink)
Originally Posted by +fireamx
I have no personal experience with the SB, or any other performance enhancing products mentioned (my car is mechanically 100% stock). But I do believe Valkryderguy knocked nearly 1/2 a second off the documented (Automotive Magazine's Road Test) 1/4 mile time of 15.18 sec. for an automatic, with nothing more than a CAI installation.
I don't know how much H.P. is needed to go a 1/2 a second faster in the 1/4 mile, but for the price of a NeedsWings "CAI", I think most "drag racers" would call it a bargain.
I know I would have when I use to drag race.
I am no expert at running quarter miles and had never done it until the last time we had a private track day.
My first 11 runs were all 15.01 to 15.18 with the stock intake.
Then I installed the Needswing CAI and my next 11 runs were all in the high 14's and my best time was 14.78.
I do have a sprint booster and I do think it opens the throttle faster than even putting it to the floor without one.
If it is only worth $2 or not I like it and that is what really matters here.
Old Oct 11, 2008 | 02:52 PM
  #54 (permalink)
lowwkeyy's Avatar
sounds simple
crack one open and post up the pics include pics of both ends of the cable.
Old Oct 15, 2008 | 11:29 AM
  #55 (permalink)
pgmikes's Avatar
Here is a "Sprint Booster technical white paper".
File Type: pdf
Old Oct 15, 2008 | 11:57 AM
  #56 (permalink)
Stogey's Avatar
We've all seen this study countless times. The argument remains !
Is it worth the 275 bucks..........................Probably not !
Is it worth the grin factor..........................Oh hell yeah !
We can just agree to disagree and be on with it.
Thats just my Dos Centavos
Old Oct 15, 2008 | 12:04 PM
  #57 (permalink)
PAULW's Avatar
MMMMMMMMMMMMM..
Old Oct 15, 2008 | 02:57 PM
  #58 (permalink)
Well said and exactly to the point.
Old Oct 23, 2008 | 09:04 PM
  #59 (permalink)
lowwkeyy's Avatar
if this is the only thing this product does then i will offer a limit supply of special edition Crossfire Extreme II drive boots that offer an adjustable 20lb weight over the right big toe . 275.00 a set
Old Oct 23, 2008 | 09:49 PM
  #60 (permalink)
ProjectMayhem's Avatar
Just so everyone knows the sprintbooster does not make your car faster. other than that enjoy
