might have screwed up the locks :(
Old Sep 1, 2008 | 08:55 AM
racermp's Avatar
Default might have screwed up the locks :(
ok, so this is my geniousnesss............ lol
so as everyones, my trunk lock line was torn in half, so i found this small 1/2" in length pipe that just slips over the original pipe,
i coated it with superglue inside the 1/2" length pipe then i put it over one end of the pipe on the car, let it dry, the original then i did the same for the pipe on the hatch side, i let it dry for a while and tested it. voila, trunk locks and unlocks now!!!
so i go to try it this morning. the passanger door and trunk stay locked. the gas cap is locking and unlocking and the drivers is working fine.
even when i open the passanger door by the door handle, the lock keeps trying to stay locked, it wown't stay unlocked.
what should i do?
anyway to unlock a locked hatch if there's no vacuum pressure to it?
thanks for any help
Old Sep 1, 2008 | 12:33 PM
racermp's Avatar
Default Re: might have screwed up the locks :(
ttt anoyone know where the pipe from the passanger door and hatch lead to? or where the pump is
Old Sep 1, 2008 | 01:56 PM
maxcichon's Avatar
I think it's under the carpet and pad in the rear hatch.
Old Sep 1, 2008 | 02:46 PM
rcompart's Avatar
there are three pipes that come out of the lock/unlock vac pump: Drivers Side Door, Passenger Side Door/Rear Hatch and the Fuel Door. There is a " T " in the line behind the interior panels right next to where the fuel door with a wersbo fitting there. I'd recommend just getting some new airline from a shop that works on semis and replace the part that cracked. The pipe you'll need is what they would use for behidn the dash for the air pressure and brake gauges. You may have it sealed up with the superglue but it could have ran down from the crack and into the rest of the system and is blocking the pipe. I don't know why it would want to try to stay locked but perhaps it has enough vacuum in the line or something. Hopefully, you didn't get any superglue into the pump and bugger that all up.
Hope you get it working right.
Old Sep 1, 2008 | 04:12 PM
greenie's Avatar
Do you have a coupe or roadster? If it's a roadster, there is a sensor in the cover for the top. If it doesn't think the cover is completely closed, it won't let you open the trunk.
This happened to me a couple of days ago. If yours is a roadster, try cycling the top up and back down completely again.
Old Sep 1, 2008 | 06:21 PM
racermp's Avatar
Thank you very much for the write up. this is very helpful. i'll take out the right side interior panel and see where the pipe is clogged. i think it maybe at the junction. i'll prolly just get new piping from the dealer.
thank you very much!
Old Sep 1, 2008 | 06:22 PM
racermp's Avatar
hey, it's a coupe. no easy switch here lol thanks
Old Sep 2, 2008 | 03:15 PM
racermp's Avatar
does anyone know how to open a locked trunk since the vacuum is not working?
thanks
Old Sep 2, 2008 | 08:10 PM
racermp's Avatar
ttt, anyway to unlock a locked hatch if there's no vacuum pressure to it?
thanks
Old Sep 4, 2008 | 11:39 AM
racermp's Avatar
ok so i got the trunk open!!!!!
ok this is what i did. i pulled down the top of the hatch, (by teh 3'rd break light) and pulled out the yellow tube from the clotch tape surrounding it, it was already broken between the hatch and body so i just pulled it till i could get to the open end, i blew thru the pipe, and it clicked YAY. it unlocked.
ok so i took off teh trunk right carpet, the pipes are all clogged. both to the door and from teh hatch (this i will replace. to the door, i'm gonna try finding where it's actualy clogged, then i might just put in a drop of paint thinner to loosen the glue.
i'm gonna try this on teh broken pipe first.
the T junktion is ok, the pump is ok, it's blowing and sucking air.
Why couldnt' it all be electric acutators. wtf with air. gay
Old Sep 4, 2008 | 01:04 PM
rcompart's Avatar
Don't kid yourself, air is cool! Youd be saying the same thing if the electric actuator went out on it only you'd be crawling over the seats adn craming yourself into the back hatch with a screwdriver taking off the interior trim and prayin to god you could get it spun around some how. I love the air locks, thay have more mechanical force, make a cool littel noise when you hit them and c'mon, they "slide" up and down so smoothly!
Glad to hear you got it figured out though. Kinda wonder about why the plastic got brittle and cracked. that stuff is usually pretty resiliant and tough and takes a lot to mess up. If I were you, I'd take the time to just run a whole new line tothe hatch instead of patching the hose that went bad because you don't know what's in the lines now and with you getting it all unlocked, bee a good time do that. Would hate to see thie being the precursor to something going wrong with all of them. You know how hard it is to crawl over this center console in our cars if you're not a midget(in all political correctness, little person).
Good luck and let us know how it goes.
RamblinShamblin
Aug 12, 2017 10:55 PM
Mackel
Oct 16, 2015 09:03 AM
Selbyl
Sep 26, 2015 04:15 AM
xjken
Sep 13, 2015 10:18 PM
jaesa
Sep 7, 2015 01:50 PM
