please help, my brother is stranded in his crossfire
Old Sep 17, 2008 | 08:11 PM
XfireX's Avatar
Default please help, my brother is stranded in his crossfire
my brother was at work in his 2004 coupe crossfire limited and he went to the car to leave but the engine wont turn on...anything he can do any suggestions?
Old Sep 17, 2008 | 08:23 PM
Voyager's Avatar
Default Re: please help, my brother is stranded in his crossfire
it is probably just the battery. tell him to call someone that has jumper cables
Old Sep 17, 2008 | 08:25 PM
XfireX's Avatar
jumping the car didnt work, the car doesnt even go "tik tik tik" it just wont start, maybe its the ecu??
Old Sep 17, 2008 | 08:29 PM
Voyager's Avatar
has he done anything to the ecu?
Old Sep 17, 2008 | 08:30 PM
XfireX's Avatar
absolutely nothing
Old Sep 17, 2008 | 08:38 PM
kloller's Avatar
Shoot it.............
Old Sep 17, 2008 | 08:40 PM
tighed1's Avatar
Does he have power to everything else, just no cranking???
Old Sep 17, 2008 | 08:42 PM
XfireX's Avatar
yeah lights everything comes on, just no engine response
Old Sep 17, 2008 | 08:51 PM
tighed1's Avatar
Sounds like it may be one of the common problems I've found on this site. Could be the relay control module.
Go here https://www.crossfireforum.org/forum...ad.php?t=27288
Gives the part number and cost. Seems to be cheaper from the MB guys'.
Do a search on "relay control module" and you will see the symptoms are similar to yours.
Good luck, report back if that's it.
(it is)
Old Sep 18, 2008 | 02:00 AM
crossfirefun's Avatar
Some have had luck giving the ecu a good rap. This might jog it enough to get it running and bring it home.
Worth a shot and doesn't cost anything.
Old Sep 18, 2008 | 04:07 AM
ppro's Avatar
AAA - priceless
Old Sep 18, 2008 | 04:32 AM
04xfirecoupe's Avatar
Originally Posted by ppro
AAA - priceless
Paid for itself the first time my crankshaft position sensor went FUBAR.
Old Sep 18, 2008 | 06:12 AM
Stogey's Avatar
Have him open the hood, find the relay control module containment over by the battery and give it a good whack with the handle of a screwdriver or something with similiar weight and mass. This may get him home. I would definetly look into replacing the RCM !
Just my Dos Centavos
Old Sep 18, 2008 | 07:10 AM
Thomas B. Whyle's Avatar
Have your brother check to see if the keyless remote is working: Sounds like a dead battery in the remote. If so, have him change the remote battery and reprogram the key fob as described many times in the forum. The car probably won't start because it doesn't recognize the key. TBW
Old Sep 19, 2008 | 06:12 AM
tighed1's Avatar
So, did ya get it running yet???
What was the problem?
Old Sep 19, 2008 | 06:22 AM
Maybe he's still walking?!
Old Sep 19, 2008 | 11:17 AM
huudoo's Avatar
key fob battery does not matter.... i took my batteries out one kight at work waited all day ''
when i got off work put the key in with no batteries and drove home 25 miles no problems
ultrajim49
17
Jun 27, 2015 12:20 AM
MJPowers
Jun 8, 2015 02:34 AM
JEFASOLD
Jun 1, 2015 08:35 PM
imported_mightyjlr
Detail Shop
59
Feb 7, 2006 08:53 PM
only1jt
Aug 18, 2003 04:39 PM
