Intermittent lamp out warning light
Old Sep 18, 2008 | 07:22 AM
bogieman's Avatar
Default Intermittent lamp out warning light
I got this warning today. I do not have any lights out. The warning will not repeat. Anybody else have this problem? I searched the web and came across a review where this was the first of many electrical "anomalies" I have only had the xfire for 2 weeks-this might be premature, but I hope I haven't bought someone else's headache.
thanks
Old Sep 18, 2008 | 08:40 AM
Hairydalek's Avatar
Default Re: Intermittent lamp out warning light
I had something like this, and I took it to be looked at as I had only had the car for a week or so. Sometimes the warning light would be on, other times it would be off. They said that the filament in one of the lights was starting to fail. They replaced the suspect bulb, and since then I haven’t had the problem.
Old Sep 18, 2008 | 09:34 AM
msheredy's Avatar
Check your license plate lights. I couldn't figure mine out either, then one night I walked around my car looking at side markers etc and noticed that only half my plate was illuminated...
Old Sep 18, 2008 | 11:21 AM
danimal's Avatar
Originally Posted by msheredy
Check your license plate lights...
Exactly!! When I get the occasional lamp out light, I can usually just tap on the license plate light and it will pop back on. The way it is designed, just closing the hatch will cause them to lose contact.
Old Sep 18, 2008 | 12:43 PM
Hairydalek's Avatar
You won’t believe the problems a twitchy number plate lamp caused me when I had the Morris Minor. Turn a corner, the rear lights went out. Stationary, the lights were fine. It took ages to track down. Part of the connector, a piece of copper strip, was slightly out of shape, and straightening it out solved the problem. When the car moved, the strip would move off the bulb and break the circuit.
Old Sep 20, 2008 | 12:29 AM
John Webster's Avatar
Just ran into this. Turned out to be the right license plate bulb. The bulb is only available from Chrysler, auto parts stores do not even list it. Only $3 from your local stealership but you have to order it in advance as they do not stock it. Comes in a bag with a Mercedes part number.
Old Sep 25, 2008 | 03:19 PM
bogieman's Avatar
Thanks guys, you were right. It was one of the license plate lamps. Happened 3 times in the past week and I finally caught it.
Old Sep 27, 2008 | 10:49 PM
NeverEnough's Avatar
I too was the victim of the phantom bulb outage indicator. It was the Lic.Plate Lamp. Mine was loose...
Old Sep 28, 2008 | 06:19 PM
mikeintorontoe's Avatar
I've got a 2005 coupe. My headlight just went out! I drove my crappy Sunfire for 10 years without having to replace a headlamp. No warning light though. Any chance this might be covered under warranty? I'd imagine a headlamp is not a cheap item for this car. By the way, I love my Crossfire!
-Mike
Old Sep 29, 2008 | 07:09 AM
maxcichon's Avatar
-Mike
I doubt they would replace it, but give it a try!
If you end up doing it your self, It's a bit of a pain. Read up on it in the "Lighting" forum. There are a number of tips to doing the job without removing the assembly.
I replaced all 4 of mine with Sylvania SilverStar Ultras. Brighter. Many will tell you to go with am HID conversion while your at it. Your choice!
Old Oct 22, 2008 | 04:16 PM
abenaki's Avatar
Why do you need a "special" Chrysler bulb for the tail light? I bought what certainly appears to be an exact replacement for 3 dollars....the specifications are identical, but I still have the warning lamp on?? I also replaced one of the running lights, but the light is still on....??? What is special about the Chrysler bulb...it appears to be just a bulb.
PNA
Nov 12, 2020 04:44 PM
wootto
U.K.
Aug 16, 2020 07:55 PM
xfireohio
Jul 20, 2020 12:03 AM
jgreen
106
Sep 18, 2017 11:46 PM
westonrose
Jul 14, 2015 11:25 PM
