clutch
Old Sep 24, 2008 | 05:11 PM
#52's Avatar
#52
Default clutch
hey lost my clutch with 3ooo miles any suggestions soft up top hard last 3/4 wont hit nuetural safety switch this is a 2006 coupe base
Old Sep 26, 2008 | 03:27 PM
Goldwing's Avatar
Default Re: clutch
What is this, a rap question?
Ask again in English.
Old Sep 26, 2008 | 05:35 PM
#52's Avatar
#52
Default Re: clutch
i omly have 3000 miles on my 2006 crossfire and i was racing with the porsche club went to downshift and my cluth disengaged but could notdowmshift when the car came to a stop the clutch depresses about 3/4 of the way to floor wont go far enough to hit safety swith or put car in gear broke hydraulic line at fittig under car and pedal than goes to floor wondering how throwout bearing works is there anoter slave in bellmousing thanx for reply
Old Sep 26, 2008 | 05:49 PM
Shawnkey's Avatar
Default Re: clutch
Sounds like a btoken clutch fork from your broken english. If you car is still under warranty, (by time) and the disc or pressure plate are not the issue, it should be covered. If they have to put a new clutch in it, then you have to pay. They are only covered for 12 months 12,000 miles, whichever comes first. If it does need a new clutch I would recomend an aftermarket performance one such as Spec. I just don't like the feel of the clutch, especially while driving spiritly.
P.S. The only Porche your gonna beat is a boxster, and don't tell me your a good driver either, because based on your issue, the argument doesn't fly.
Old Sep 26, 2008 | 06:11 PM
#52's Avatar
#52
Default Re: clutch
not here to argue or brag but yes i do run well with most of the porsches but i am also running 18 inch all the way around with 80 tradwear pilotcups and the 3000 have all been on track with exception of first 250 i have been to dealer they wanted 500 tear down fee to let me know if it is under warranty thought that was b.s so i will do the work myself any suggestions on aftermarket clutces thanx
Doug
Old Sep 26, 2008 | 06:17 PM
anthony grubel's Avatar
Default Re: clutch
it seem that your pressure plate let go i think its comun on the crossfire good luck in finding a pressure plate you will also find out when removeing your trans. that they put loctite on the bolts its going to cost you big time
Old Sep 26, 2008 | 06:48 PM
#52's Avatar
#52
Default Re: clutch
anthony thanx for the heads up will carry knuckle bandaids to shop
waldig
Aug 24, 2015 10:40 PM
needfreetime
Aug 1, 2015 07:06 PM
UNDER PSI
Aug 1, 2015 02:11 AM
ricardo 53
Jul 21, 2015 07:49 AM
BlackCrossFire6spd
Aug 21, 2006 10:48 AM
