Broken oil filter shaft
Old Oct 2, 2008 | 04:25 PM
jimmyjazzbo's Avatar
Default Broken oil filter shaft
I recently did my first oil change. I followed some of the Forum's instruction; which were very helpfull. When I took out the oil filter, about 6 1/2 inches of the plastic shaft remained in the engine. I don't know if it was broken before or not. I left it in there and replaced the filter and screwed the remainining shaft accordingly. It has been fine. I have since bought a new oil filter assembly and will install it soon. My question is: how hard is it to get the old remaining shaft out of the engine without doing any more damage to it.
Old Oct 2, 2008 | 04:30 PM
Default Re: Broken oil filter shaft
wow, it should just pull out....someone must have forced in there or forced it out...couldn't imagine one breaking like that, but there you go....you have one...
Old Oct 3, 2008 | 03:12 PM
CRM's Avatar
CRM
Really only one reason for that to happen...you did not get the filter seated completely into the housing before you reinstalled it the last time. When you reinstalled it,you screwed the top back on, the filter bottomed out in the housing allowing the center to be twisted off as you tightened the cap.
Most of the better filters now come with a line on the filter that allows you to see if is completely seated before you reinstall it.
The broken off portion should pull right out of the housing.
Old Oct 3, 2008 | 03:26 PM
danimal's Avatar
Are you sure that it is 'broken' off.....I was under the impression that the shaft just snaps into the cap. I could be entirely wrong on this and I will look at it more closely on my next oil change. It just seems awfully intricate for that whole shaft and cap to be molded as one piece.
Old Oct 3, 2008 | 05:26 PM
thomatt12's Avatar
It probably got broken when you were taking it off. Maybe you used too much force pulling it off or something.
_______________________
car parts
Old Oct 16, 2008 | 06:52 PM
TVT_DESIGN
Guest
Posts: n/a
The oil filter is technically 2 pieces and the shaft does come off, not easily though.
I can't imagine how it ended up coming off though.
Old Oct 18, 2008 | 10:54 PM
GB'sXFire's Avatar
There's one listed on ebay today, 10/18/08. Don't know how to make a link to it, but search chrysler crossfire and itemize by "newly listed" and look for 10/18/08.
Old Oct 19, 2008 | 09:04 AM
70GT6's Avatar
http://cgi.ebay.com/ebaymotors/04-08...d=p3911.c0.m14
Old Oct 19, 2008 | 09:25 AM
GB'sXFire's Avatar
Show off! j/k
Old Oct 19, 2008 | 09:29 AM
70GT6's Avatar
Show off! j/k
Na showing off would be hiding it in a pretty link like this:
Filter-Tube
Old Oct 19, 2008 | 04:09 PM
CRM's Avatar
CRM
I think I would check with a Mercedes dealer if you have one close...I don't think they are that expensive.
syfi
Mar 28, 2026 04:14 PM
TerryR
Dec 13, 2019 03:27 PM
jimf
Oct 10, 2015 10:22 AM
o55ie18
Oct 5, 2015 05:50 PM
Sep 28, 2015 07:40 PM
