Fuel Injectors!
Old Nov 24, 2008 | 01:52 PM
kolevski's Avatar
Default Fuel Injectors!
I have two questions here,
1. Can you put/fit the SRT-6 fuel injectors in our base model.
2. If so will it make a difference, e.g. the same difference as if you were to buy the aftermarket TVT fuel injectors.
Old Nov 24, 2008 | 05:47 PM
RealSER's Avatar
Default Re: Fuel Injectors!
Adding larger fuel injectors won't increase power output unless the stock ones aren't able to supply enough fuel (i.e. the car is running lean and the injectors' duty cycle is maxed out). Given that, in stock form, the car runs rich, adding larger injectors really won't help. Also, if you watch the AFRs, they tend to drift to around 12.0-12.5, which is rich for an NA car. I've disco'd the battery, resetting the ECU, in order to watch the AFR's adjust over time. Immediately after begin reconnected, the car ran extremely rich (~11.0-11.5) and slowly adjusted to 12-12.5. I'm willing to bet that if you add new injectors and don't tune them at all, initially the car will run extremely rich (< 11.0AFR) and eventually the ECU will pull fuel so that the AFRs are adjusted back to 12.0-12.5.
Old Nov 24, 2008 | 05:54 PM
splinter's Avatar
*off topic*
RealSER: Do you have a link to your other car on a SE-R forum? Yours sounds very interesting!
Old Nov 24, 2008 | 06:04 PM
kolevski's Avatar
Thanks for that RealSER, what your saying sounds pretty accurate, Do you know if I was to get bigger injectors AND had my ecu tuned to them whether or not it would help my power increase?
Old Nov 24, 2008 | 06:29 PM
TVT_DESIGN
Guest
Posts: n/a
You will need to retune the ECU to any larger injectors. The injectors we offer are a more efficient design as the OEM MB injectors in both the AMG and non-AMG models.
You can always tune down the fuel on a car, but without major mods these cars will not need anything more then 17 lbs/hr injectors.
Plus I think the SRT injectors are fairly pricey.
Old Nov 24, 2008 | 06:54 PM
RealSER's Avatar
Ideally, you should complete all the bolt-ons/mods you plan on installing, then get the ECU tuned based on those mods.
Offtopic: this is the link: http://myspecv.com/f/t10208.html to my other car, most of the pictures are over a year old.
Old Nov 24, 2008 | 07:29 PM
kolevski's Avatar
The TVT set up is great, my only disadvantage is being in Australia. So I kind of have to make do with what I can purchase down here. But thanks for all your input been a great help.
Old Nov 26, 2008 | 11:45 AM
sonoronos's Avatar
1. Yes.
2. NO.
No Nein Nicht Bu Tsi Bad Nada Bad Idea Bad Idea.
Old Mar 11, 2009 | 07:46 PM
kolevski's Avatar
Hey guys, I've just been looking back at this thread and looking at it now everyone is saying bigger injectors wont increase power, then how come TVT is selling injectors and saying it'l increase your power? Plus I've read many members here saying the N/A's injectors are far to small. Any thoughts? and for the record which injectors are actually bigger the SRT, TVT or MB V8?
Old Mar 12, 2009 | 08:18 AM
sonoronos's Avatar
It's because TVT also supplies engine tuning.
Old Mar 13, 2009 | 08:18 AM
Glockhit's Avatar
I have the TVT 265 kit and a sprint booster. The larger injectors are useless without a computer modification (flash) and a good CAI, etc.
These huge injectors really kick in when the Limited is floored and you hit around 60mph. From that point you can hit 120 mph plus extremely fast. They also do a good job straight off the line. Only if you have the appropriate flash done though. You need the whole package.
rmcdaniel12
Nov 4, 2015 04:08 PM
Oct 1, 2015 01:42 AM
Sep 25, 2015 02:16 AM
Sep 23, 2015 09:14 AM
04Fire
Sep 15, 2015 07:40 PM
