In need of new keys!!!
Old Dec 19, 2008 | 02:45 PM
07bluezx14's Avatar
Question In need of new keys!!!
I'm sure there is a post about this already, But I have one key fob that won't work remotely, but still starts the car. The other one is broken where it would attach to a key ring, and looks very worn. So I need atleast one, but prefferably two new ones. I tried emailing the local chrysler dealership, with no response. Thought I would see where you guys are getting yours, and what to expect to pay for one, or two. I understand programming isn't an issue. Do they just need your vin number to get the right key? Thanks in advance, chris
Old Dec 19, 2008 | 02:55 PM
robby363's Avatar
Default Re: In need of new keys!!!
If the key starts the car you should be able to program the remote. Put the key in the ignition and within 1 or 2 seconds press one of the lock or unlock button twice then turn the key to run/start and it should program it to lock and unlock it.
Old Dec 19, 2008 | 02:56 PM
007_MI6's Avatar
VIN# and proof of ownership. I have seen people get them for $90-$150, my dealer wants $148. There are plenty of threads on the topic here too, might just need to try different search words. Good luck.
Old Dec 19, 2008 | 03:57 PM
huudoo's Avatar
one of our member posted this a while back
This is straight from the Crossfire manuals supplied to the dealership, or if you are a Chrysler tech, I got it from Tech Connect.
STANDARD PROCEDURE - TRANSMITTER PROGRAMMING
The Remote Keyless Entry Transmitter(s) can be programmed by the customer without special tools.
PROGRAMMING PROCEDURE
Transmitter programming by the customer is done by performing the following steps:
  1. Insert the key into the ignition switch.
  2. Press either the lock or unlock button momentarily twice.
Turn the key in the ignition switch to the ON/RUN position within 30 seconds.
Hope this is useful and saves you $100.
Shawn
Old Dec 23, 2008 | 02:32 PM
CobraMike's Avatar
The Key can still start the car if the transmitter goes bad. Mine did the same thing. I had to take my VIN and Registration to the dealer so they could order new keys. They cost about $100 each and according to the dealer required the keys to be programmed using the Chrysler Diagnostic tool. ( Although I never tried the procedure above )
Some Parts stores have a Key Fob tester that will test if a signal is coming out of the transmitter. Most Autozone stores have them. I would try that first.
I am now very careful with my keys now. Mine died after my 2 year old dropped them.
fastfred
Nov 5, 2018 09:47 AM
o55ie18
Oct 5, 2015 05:50 PM
DaveMe
U.K.
Sep 29, 2015 08:09 AM
Padgett
Southeast Forum
Sep 27, 2015 09:37 AM
fastfred
Sep 24, 2015 03:05 PM
