wheel offset question
Old Jan 25, 2009 | 05:48 PM
j-fire's Avatar
Default wheel offset question
i am planning on installing a set of 20x10's in the rear with a 42mm offset. will this look right? or will they be shoved under the car and not clean and flush with the fender wells? anyone install a setup like this? will a 15mm spacer be sufficient enough to fix the problem? (assuming there is a problem)
thank-you so much in advance for your help!
Old Jan 25, 2009 | 06:03 PM
maxcichon's Avatar
Default Re: wheel offset question
I think you will need at least a 20 mm spacer set to return to OEM offset. Much will depend on the size/aspect of the tires you choose.
Use this tool:
http://www.rims-n-tires.com/rt_specs.jsp
and put OEM info on the left and proposed/new info on the right and clearances will be shown both graphically and in the boxes below.
See also the Sticky "Wheel Spacers" here:
https://www.crossfireforum.org/forum...ad.php?t=25349
Lots of good info.
Old Jan 25, 2009 | 07:42 PM
no spacer needed if you have a 2" lip on the wheel here is a 17" /with 42 offset with D R on them jim
Old Jan 25, 2009 | 08:13 PM
j-fire's Avatar
wow. great looking setup!!! and thanks so much for the info! i am so relieved they will work.
thanks jim!
oh, and the lip on them are 3.5" so i think that will be plenty!
Old Jan 26, 2009 | 06:44 AM
maxcichon's Avatar
Looks nice Jim.
I just ran the mock-up and it shows, that if you choose 275/30 X 20 with a 42 offset, (only 2% larger for the speedo) the tire will be 1.2 inches closer to the interior wheel well.
Sorry, I uploaded the wrong .pdf file.
20's pdf is what what you want
File Type: pdf
File Type: pdf
Old Jan 26, 2009 | 06:48 AM
MisterTaz's Avatar
Hi MAx,
Check the attachment; I don't think it was wehat you expected to post?
Cheers
Old Jan 26, 2009 | 06:54 AM
maxcichon's Avatar
Yep, I noticed it straight away. The right one is there.
Damn, you're fast!
It's a Taz thing, right?
Old Jan 26, 2009 | 10:15 AM
j-fire's Avatar
i've got 285/30/20 p Zero's for the rears.
thanks so much for all the info guys, i REALLY appreciate it!!
Old Jan 27, 2009 | 09:09 AM
NoCones's Avatar
the lip has nothing to do with whether the wheel is going to sit flush or not...offset and width are driving that alone
Kodebuster
Nov 5, 2020 04:06 PM
xfireohio
Jul 20, 2020 12:03 AM
RojoGTO
Feb 6, 2016 11:14 AM
firefly04
Aug 26, 2015 03:08 PM
tom2112
Jul 28, 2015 08:12 AM
