So, this fell out when the door was opened...
Old Mar 5, 2009 | 09:35 PM
smokey847's Avatar
Default So, this fell out when the door was opened...
A friend and I were leaving the local Chinese restaurant this evening but when he opened the passenger door, we heard a big clank! We both looked at each other and he picked up a weird looking black metal piece from the ground. So what is this thing? Why did it fall out? Thanks!
Old Mar 5, 2009 | 09:41 PM
+fireamx's Avatar
Default Re: So, this fell out when the door was opened...
It's just a cover at the top of the door, (inspection cover?) that is held in place by a couple of star head screws. The screws probably just came loose that's all.
Old Mar 5, 2009 | 09:50 PM
Moparrbust's Avatar
Accent cover............screws onto upper end of the door trim panel.
Old Mar 5, 2009 | 09:54 PM
smokey847's Avatar
Great! No big deal then. Wonder what caused it to loosen? I've noticed lately that if someone closes the door a little hard, you can hear like a metal clanking noise-- probably this thing slamming against the body...
Old Mar 5, 2009 | 09:59 PM
Moparrbust's Avatar
Two baby phillips screws somehow backed their way out and the piece fell off.
Old Mar 5, 2009 | 10:03 PM
smokey847's Avatar
Thanks for the quick responses!
Old Mar 6, 2009 | 09:11 AM
Use a Torx screwdriver #9, not a Phillips unless you use a Phillips screw. These screws mess up real good if you use the wrong driver.
Old Mar 6, 2009 | 01:03 PM
The Beep's Avatar
What did the fortune cookie say?
Old Mar 6, 2009 | 04:14 PM
smokey847's Avatar
You should enhance your feminine side at this time. HA HA!
Old Mar 6, 2009 | 06:23 PM
danhaman's Avatar
No joke. These are the ones that are just a little bit smaller than all the rest in the door right? I tore mine up good, just didn't have a driver that small. Anyone know where to get replacements?
Dh
Old Mar 6, 2009 | 06:34 PM
ppro's Avatar
Dh
Look them up on the parts list in the factory service manual and then order them online from Boltdepot.com
OR go to the dealer...
Old Mar 6, 2009 | 11:22 PM
Moparrbust's Avatar
Huh, the one base Crossfire I worked on had little phillips screws in it............must have changed them out. I know M-B uses torx on almost all of their cars and Chrysler usually puts cheap azz phillips instead.
Old Mar 7, 2009 | 08:04 AM
Mine are Torz allright, had them off for the door rust problem photos.
Osusannah
Feb 12, 2024 01:49 PM
Valk
Jul 12, 2021 09:49 PM
Mackel
Oct 16, 2015 09:03 AM
Billy22Bob
Sep 28, 2015 08:08 PM
jaesa
Sep 7, 2015 01:50 PM
