Hey what kind of wheel is this? I think this would look pretty awesome on an Xfire
Old Mar 15, 2009 | 09:41 PM
MAYAman's Avatar
Default Hey what kind of wheel is this? I think this would look pretty awesome on an Xfire
Old Mar 15, 2009 | 11:37 PM
jonnyangel04's Avatar
Default Re: Hey what kind of wheel is this? I think this would look pretty awesome on an Xfire
sl 55 or 550? the mercedes boys will know better then I do
I like the newer style with the dark gray lip in the center
http://cgi.ebay.com/ebaymotors/18-Me...Q5fAccessories
http://cgi.ebay.com/ebaymotors/amg-c...Q5fAccessories
Old Mar 16, 2009 | 03:08 AM
Skyshadow's Avatar
Very clean wheel. but the set in the photo look like 19's or 20's, much bigger then the Ebay pics??
Old Mar 16, 2009 | 05:24 AM
MAYAman's Avatar
Can anybody give me the exact measurments I would give the wheel guy so I could get these in 19 up front and 20 in the rear without rubbing? Pretty please.
Old Mar 16, 2009 | 06:08 AM
ImportLabSRT's Avatar
Those are 19" Accessory wheels for the SL500/550. Or SL500/550 with AMG styling package.
Old Mar 16, 2009 | 07:45 AM
MAYAman's Avatar
Ok but what size in 19 and 20 would I ask for so they will fit. I have mo idea
Thanks
Old Mar 16, 2009 | 08:23 PM
s40guy's Avatar
They are 19" AMG Spec wheels that came standard on AMG CLS Models and were optional on a few others. Bolt Pattern: 5 x 112mm Size is: 19 x 8.5
Check this:
http://images.google.com/imgres?imgu...a%3DN%26um%3D1
Old Mar 16, 2009 | 11:05 PM
MAYAman's Avatar
OK thanks guys but nobody is answering my question. How do I get these on the crossfire? I don't mean to sound rude but I know nothing about wheel sizes or offsets, I just know what looks good.
What size do I have to buy these to make them fit without rubbing or other crap?
thanks
Old Mar 16, 2009 | 11:08 PM
thanks
i had 19 by 8.5 in the front with a 30 mm offset and a 20 by 9.5 rear with a 35. if I had to do it again I would go 19x8.5 35 and 20x9.5 45. tire sizes is the problem dont go wider then a 30 up front and you should be fine
Old Mar 17, 2009 | 06:57 AM
MAYAman's Avatar
Thanks man!!!
Old Mar 17, 2009 | 07:13 AM
nate_man's Avatar
Well here is some additional info from tire rack that helps with the offset question:
The offset of a wheel is the distance from its hub mounting surface to the centerline of the wheel. The offset can be one of three types (measured in millimeters).*
Zero Offset
The hub mounting surface is even with the centerline of the wheel.
Positive
The hub mounting surface is toward the front or wheel side of the wheel. Positive offset wheels are generally found on front wheel drive cars and newer rear drive cars.
Negative
The hub mounting surface is toward the back or brake side of the wheels centerline. "Deep dish" wheels are typically a negative offset.
If the offset of the wheel is not correct for the car, the handling can be adversely affected. When the width of the wheel changes, the offset also changes numerically. If the offset were to stay the same while you added width, the additional width would be split evenly between the inside and outside. For most cars, this won't work correctly. We have test fitted thousands of different vehicles for proper fitment. Our extensive database allows our sales staff to offer you the perfect fit for your vehicle.
gblack32
Sep 7, 2016 08:27 PM
Tp'sfury
Aug 13, 2015 08:20 PM
2004_
Jul 29, 2015 05:17 PM
3spencer3
Jul 24, 2015 01:08 PM
Blackout317
Jul 7, 2015 08:38 PM
