Potential rust location
Old Mar 17, 2009 | 02:01 PM
70GS455's Avatar
Default Potential rust location
I just noticed as I was opening my hatch today that there is rust starting to form under the paint. It is a small area surrounding the handle that is used to open the hatch. I don't know if water is intruding above from the wing or emblem area, or if water has just splashed up from the outside and somehow gotten between the plastic handle housing and the metal. Might be something to be checked.
Is this something that should be covered under the corrosion warranty?
Old Mar 18, 2009 | 06:24 AM
kingkub57's Avatar
Default Re: Potential rust location
This same thing is happening to my car also, took it to the dealer and they repaired it under warranty, but I am under the 3/36 warranty still. I'm thinking that because it is exposed to the elements, and that there is not enough paint around the edge of the opening for the handle assembly, is why its starting to rust, so keep a look out for that area too, with the wheel wells and the door seal area's as well.
Old Mar 18, 2009 | 07:27 PM
Kurts's Avatar
You guys don't mention if you own SRT-6's or not.
There is a thread around here somewhere that pertains to a rust issue under the SRT wing.
https://www.crossfireforum.org/forum...ght=SRT-6+wing
If that is the issue that would help explain why you're getting rust on the hatch release.
Old Mar 18, 2009 | 08:13 PM
70GS455's Avatar
My particular case is a non-SRT. I'm wondering if the electric wing assembly has seals or o-rings like the fixed wing.
Old Mar 19, 2009 | 05:03 AM
GDC-SRT's Avatar
Rust should be thought of as a slow fire. Fire is fast oxidation, Rust is slow oxidation.
If you take away any of the three needs, oxidation is stopped.
Fire needs three things
1. fuel
2. heat
3. oxygen
Rust also needs three things
1. metal
2. moisture
3. oxygen
TerryR
Dec 13, 2019 03:27 PM
aerobluehal1
Canada
19
Oct 13, 2018 09:47 AM
Steven 4190
Nov 25, 2015 10:12 AM
ritous1
Sep 26, 2015 01:27 PM
AlbertFattal
Sep 24, 2015 05:03 AM
