Front Tires Stuck, Embarrassed to ask
Old Apr 10, 2009 | 11:55 AM
JasonSmith's Avatar
Default Front Tires Stuck, Embarrassed to ask
so Im trying to get my front tires off and I can't. I took the lugs out but I cant free to tire to get it off to access the fog light. Help ?!?!?
Old Apr 10, 2009 | 11:58 AM
danimal's Avatar
Default Re: Front Tires Stuck, Embarrassed to ask
A good swift kick to the tire with the sole of your shoe should break it free.
Old Apr 10, 2009 | 12:01 PM
faiz23's Avatar
yup best tool you got swift kick to the tire not the rim that would suck lol
Old Apr 10, 2009 | 12:02 PM
H82BL8's Avatar
You could just bolt em back up and crank the wheel hard, right or left to get access?
Panthro's Avatar
Is the car jacked up? Sorry I had to ask. If it is, the wheel should just be sitting on a rounded protrusion and after you remove the 5 bolts the wheel should come straght off. If you are having problems, try grabbing the wheel by the spokes close to the center and lift slightly and pull twords yourself.
Old Apr 10, 2009 | 12:04 PM
JasonSmith's Avatar
Yeah it was off the ground. A swift couple of kicks took care of it. Thanks guys
Old Apr 13, 2009 | 03:32 PM
Goldwing's Avatar
It's probably too late now, but I always put a little lithium grease around the metal hub to keep the rim from rusting on. That's why it is difficult to remove.
PNA
Nov 12, 2020 04:44 PM
Kodebuster
Nov 5, 2020 04:06 PM
Bayukbros
Jul 29, 2015 10:16 AM
tom2112
Jul 28, 2015 08:12 AM
axnguyen
Jul 21, 2015 11:41 AM
