Eibach lowering springs. Correct info?
Old May 2, 2009 | 04:05 PM
Glockhit's Avatar
Default Eibach lowering springs. Correct info?
This was information supplied to me about eibach lowering springs from a dealer . Is this correct.
quote:
"Due to the fact that the ride height will change once the springs are installed all the settings will have to be adjusted to compensate. Not doing so will cause your steering feel to be mushy & your tires will wear noticeably within 2-3 weeks."
It was my understanding that this wasn't necessary. Thanks in advance.
Old May 2, 2009 | 04:34 PM
Default Re: Eibach lowering springs. Correct info?
I can tell you I didn't even do an alignment and I added spacers. Some will tell you they did an alignment, and that probably OK too.
No issue here.
Old May 2, 2009 | 07:35 PM
JaneBridges's Avatar
I had to have my camber readjusted as I ended up at -3, instead of -2.
Old May 2, 2009 | 08:05 PM
07bluezx14's Avatar
I was under the impression, that when you changed your shocks and struts, you needed an alignment, unless you could do it by sight. But the last to cars that I modified the suspension on I did both springs, and s/s. But I'm sure there are exceptions.
Old May 2, 2009 | 08:34 PM
805_Fire's Avatar
Has anybody lowered their car with 19's in the front and 20's in the back? I'm thinking about lowering my car, have 2nd thoughts because of the rim size.
aerobluehal1
Canada
19
Oct 13, 2018 09:47 AM
thatcham
Oct 5, 2015 02:41 PM
2005 Ragtop
Oct 3, 2015 03:01 PM
4drturbo
Oct 2, 2015 12:58 PM
Oct 1, 2015 01:42 AM
