Cob Webs In Headlight?
Old May 17, 2009 | 11:49 PM
Crossfire725's Avatar
Default Cob Webs In Headlight?
how can i get the cob webs out of my driver side headlight. can i simpley just take off the front plastic?
please let me know. its pissing me off lol
thank you for your time
Old May 18, 2009 | 08:02 AM
bluecoupe's Avatar
Default Re: Cob Webs In Headlight?
Taking the headlamp apart will be a lot of work. I used a pipe cleaner (fuzzy wire) inserted through the standing light hole (top outside corner) to remove a spider web from one of my headlamps and I hooked up a shop vac hose to the same hole to suck out any residual debris. Careful to round out the end of the pipe cleaner so you don't scratch the inside of the lens. Hope this helps?
Old May 18, 2009 | 09:46 AM
sounds like a good idea. do i need to take the whole headlight out in oder to take the little light out? i havnt looked yet. let me knnow ahead of time, thank you soo much
Old May 18, 2009 | 10:07 AM
bluecoupe's Avatar
Yes, much easier if you remove the headlight first. Good luck!
Old May 18, 2009 | 10:08 AM
how do you remove the headlight? i only see the 2 top screws.
Old May 18, 2009 | 10:15 AM
bluecoupe's Avatar
There's 2 more bolts in the bottom, remove the fog light splash shield to get get at 'em. Also, best to undue the bumper cover at the corner too and remove the grill. This way you can manipulate the headlamp to remove it without removing the bumper cover completely. Coincidently, gonna pop new headlamps in Beaner's car this afternoon!
Old May 18, 2009 | 10:17 AM
god dam. screw that. is it possible to remove the little bulb on the upper corner without removing the whole head lamp?
smfrycruzr
Jul 17, 2023 05:33 PM
srtmodder
Aug 23, 2017 08:28 PM
Franc Rauscher
May 9, 2016 12:04 PM
gp1200x
Nov 24, 2015 04:39 PM
RacerXofFL
Sep 15, 2015 05:00 PM
