Passenger Side Headlight
Old May 23, 2009 | 09:36 PM
Crossfire725's Avatar
Default Passenger Side Headlight
muy passenger side headlight is aiming down. i tried fooling around with the white adjuster and it dosent help? can you please help me
thank for your time
Old May 23, 2009 | 09:51 PM
apkano's Avatar
Life is random...so am I.
Default Re: Passenger Side Headlight
Did you fail to tell us that you recently changed the bulb in that housing?
If so then you don't have the bulb seated correctly in the socket. Fairly common mistake, and easy enough to fix. If you look closely at the bulb it has a flat side and a tang sticking out. This HAS to line up with the socket or the bulb will not fit correctly.
Danyuhl
Nov 2, 2019 05:18 PM
Forced382
Aug 11, 2015 09:40 PM
Charles Moore
Aug 1, 2015 02:35 PM
Charles Moore
Aug 1, 2015 02:33 PM
michaelcycle58
Jul 28, 2015 08:12 PM
