How and Where to install LED Load Equalizers
Old Jun 21, 2009 | 03:34 PM
rakoom2002's Avatar
Default How and Where to install LED Load Equalizers
I am getting some led load equalizers from super lumination:
I have led's currently in my eyebrow lights and then my license plate lights. as far as im aware from seeing diagrams the equalizers have to bridgew across the positive and negative wires like an "H"... is that correct?
Also, I dont see how to get to the wires for the license plate. do I have to take the hatch panel off? it says not to install the equalizers onto plastic because itll melt it, where did you guys install?
Old Jun 22, 2009 | 04:12 PM
Roy Mander's Avatar
Default Re: How and Where to install LED Load Equalizers
You only need load equalizers when you change to leds from ordinary bulbs where there is a load factor, for instance direction indicator lights are 21 watts each and the replacement LED only needs milliwatts, so the effect is they will not flash. hope this helps.
Old Jun 23, 2009 | 12:20 AM
rakoom2002's Avatar
I just want my "light out" symbol to go away in the dash, cant I use these load equalizers, or can I only use resistors?
Old Jun 23, 2009 | 08:14 AM
maxcichon's Avatar
Incorrect. With the light load from LED's, the car will think you have a failed bulb and give a "Bulb Out" indicator.
Old Jun 23, 2009 | 08:16 AM
maxcichon's Avatar
Those "Load Equalizers" ARE resistors.
Yes, (first post) you install them across (parallel) your bulb socket. There are different sizes (values) to emulate the different size bulbs. Make sure you get the right ones.
As for mounting. You do have to be careful not to rest them against plastic. If you must, make a simple little bracket to mount the resistor to (aluminum) with a long end and a hole in it. Mount somewhere to an existing screw.
At a show recently, a fella' had all LED's and ended up making a central mounting plate for 10 resistors. The plate was a slab of aluminum heatsink (finned). Looked danged nice!
Old Jun 26, 2009 | 12:33 AM
rakoom2002's Avatar
where did he have the plate mounted? and I thought the 15-25 ohm would work for all... I only have eyebrow, and license plate.
deerhunter
Jan 16, 2021 10:56 AM
MiamiTVR
Jan 30, 2016 02:15 PM
triplmmm
Sep 24, 2015 12:12 AM
crmnal
Sep 6, 2015 08:07 AM
steps
Sep 3, 2015 07:24 PM
