Radio - Treble / Bass controls and Dash Lights dimmer
Old Oct 12, 2003 | 07:41 AM
scooterme's Avatar
Default Radio - Treble / Bass controls and Dash Lights dimmer
I noticed whenever I set the treble and bass settings the radio defaults the settings back to Zero (0) whenever the car is turned off. Basically I have to set the treble and bass controls each time I drive the car. Very annoying - Is this right ? Also, does anyone know if there is a dimmer switch to turn down the dash light brightness ?
Old Oct 12, 2003 | 10:47 AM
gsopc's Avatar
Default
Stem on the left controls dash brightness. As you can see, the radio is an overall disgrace and the non-caring, non-responsive corporation couldn't care less!
Old Oct 12, 2003 | 12:50 PM
imported_mightyjlr
Guest
Posts: n/a
Default
My treble and bass settings stay however I set them... I would say call your dealer, because that's not how it's supposed to work.
Old Oct 16, 2003 | 02:14 AM
mouserider's Avatar
Default
The treble and bass settings are individual for each mode, so the setting you make for FM can be different from your setting for CD and they should stick.
If you push and hold the AUD key, and go through the menu, there is a setting that lets you put everything back to default flat 0-0 in all modes.
If you disconnect your battery, you will lose your settings.
There is also 3 driver memories as well.
pioneer4x4
Sep 18, 2023 11:49 AM
PNA
Nov 12, 2020 04:44 PM
mobilefitt
Jul 28, 2015 03:45 PM
pioneer4x4
Jul 27, 2015 02:04 PM
pioneer4x4
Jul 21, 2015 10:35 PM
