my headlamps seem to be eating headlight bulbs...help!
Old Aug 4, 2009 | 05:19 PM
ryan48's Avatar
Default my headlamps seem to be eating headlight bulbs...help!
I have replaced about 10 bulbs this year...any idea what the problem could be? I am not touching the glass, so that is not the issue..it's very annoying and expensive!
Old Aug 4, 2009 | 07:18 PM
maxcichon's Avatar
Default Re: my headlamps seem to be eating headlight bulbs...help!
HID's
The only way to fly...
Old Aug 4, 2009 | 07:35 PM
Kurts's Avatar
That does seem rather high!!!
Are you 100% positive that you're replacing them with the correct bulb? Check your owner's manual & make sure!
Touching any halogen bulb can be very bad so it's good to know you're not doing that! My only other piece of advice would be to clean the bulbs with some rubbing alcohol first, avoid touching them like the plague & then stuff them in.
Might not be a bad idea to do a quick visual check of the wires & the connector & make sure that they aren't pinched or frayed. Make sure the rubber cap is clean & seated properly so no excess moisture can get in there.
Old Aug 4, 2009 | 08:12 PM
bluecoupe's Avatar
I've had 2 headlight bulbs burn out since April......going with HID's very soon
Old Aug 4, 2009 | 08:56 PM
Are they burning out or is the glass breaking as you imply?
Old Aug 4, 2009 | 09:10 PM
Stogey's Avatar
What brand and type of bulb are you using ?
Old Aug 4, 2009 | 09:43 PM
GDC-SRT's Avatar
Have tested charging system for voltage, with a multi-meter?
You should be running about 14 volts dc.
Hook up the meter and try different rpms, look for a spike in volts.
Just an idea!
Old Aug 5, 2009 | 12:03 PM
ryan48's Avatar
the bulbs appear to be burning out...I have nt checked the wiring solely bc it is not the same ight everytime. The bulbs I am using are the higher end sylvania's.. I can check for misture..not a bad idea!
Old Aug 5, 2009 | 01:46 PM
Honestly, do yourself a favor and get HIDs, they are not more than a few dollars more than those Sylvanias and offer MUCH better output ( and look much better too )
There are great install instructions posted on here (I believe from Max) and it is not a difficult install.
Just my 0.02
smfrycruzr
Jul 17, 2023 05:33 PM
aerobluehal1
Canada
19
Oct 13, 2018 09:47 AM
srtmodder
Aug 23, 2017 08:28 PM
Franc Rauscher
May 9, 2016 12:04 PM
RacerXofFL
Sep 15, 2015 05:00 PM
