Broken Mirror Adjustment Knob
Old Oct 8, 2009 | 12:13 AM
rakoom2002's Avatar
Default Broken Mirror Adjustment ****
I got into the xfire the other day and noticed that for some odd reason my mirror adjustment **** had been pushed down into the center console. I have no clue how this happened, but I tried for about 15 minutes to fix it when I gave up due to no luck. Any suggestions on how to fix this?
Old Oct 8, 2009 | 12:44 AM
nox1s's Avatar
Default Re: Broken Mirror Adjustment ****
You're gonna need a whole new rear center console...Having taken apart it has happened to me. There are clips underneith that holds the switch and it sounds like yours are broken..
Old Oct 8, 2009 | 01:46 AM
rakoom2002's Avatar
Whaaaaaaaa.... whole new rear center console just for the mirror adjustment ****?
Old Oct 8, 2009 | 02:13 AM
nox1s's Avatar
Maybe not.
Reading it a second time.. it is possible that it was just pushed out, and the clips weren't broken.. It's not that hard to access if you want to check it out..
A few pieces you'll have to remove..
First, the shifter bezel (the rectangular frame) surrounding the gear selector. Use a plastic knife or something plastic wedge-like (NOT METAL IT WILL SCRATCH / WARP THE PLASTIC I KNOW FROM EXPERIENCE!!) and pull up.. you won't break it.. there are 4 clips holding it in.. feels like its gonna break but it won't
Second, the actual shifter plate, i found the best way to do this is to locate the bottom of it where there's a slight gap between the two pieces, put your wedge in there, and pry up. You can then disconnect the mirror switches
Third, there should be 2 screws holding the front end of the rear center console together, take those out.
Fourth, look inside your center console bin, at the back there's a flap of carpet. Lift that up and remove those two screws as well
Fifth, you need to remove the e-brake handle.. no trick, just pull up on the rubber grip until you get it off.. this part SUCKS and it's really hard to do.
Now you should be able to manuevur the rear console out of the latch catches and pull it off.. since your mirror switch is already through this won't be a pain in the *** if it was connected.. you should then be able to figure out if the clips are broken or it just fell through..
If the clips aren't broken, it is a royal pain in the *** to put the mirror switch in, and align the console back up.. the wire isn't very long so you don't have much room to wiggle with..
Hope that helps, 2am and did everything from memory so if you need anything else just post, I took apart my console so many times it's scary.
Old Oct 8, 2009 | 10:22 AM
rakoom2002's Avatar
Ya, Im pretty sure the clips arent broken, thanks a lot mate, I greatly aprpeciate it.
Old Oct 8, 2009 | 10:48 AM
MikeR's Avatar
Rakoom,
If you want to come by I will give you a hand. The console isnt too difficult.
MikeR
Valk
Jul 12, 2021 09:49 PM
o55ie18
Oct 5, 2015 05:50 PM
2005 Ragtop
Oct 3, 2015 03:01 PM
eatmycrackers
Sep 23, 2015 09:08 AM
jaesa
Sep 7, 2015 01:50 PM
