Suggestions for storing car?
Old Nov 4, 2009 | 04:40 PM
blackcrossfire07's Avatar
Default Suggestions for storing car?
Here is the situation.... I have an enclosed barn with a pebble floor. Is there some kind of mat that I can put down to park the car on (so it doesn't get dirty or let moisture up in the car). Maybe lay a rug down or tarp? Any suggestions or would a nice clean pebble surface be good enough? Any thoughts or creative ideas?
Old Nov 4, 2009 | 07:35 PM
waldig's Avatar
Talking Re: Suggestions for storing car?
Id suggest some type of vapor barrier and a few mouse poison bait packages under the car for the mice. Get a battery tender to keep it charged and your set. Fill the gas tank also to limit vapors and condensation. WOODY
Old Nov 4, 2009 | 08:35 PM
Hawk Monster's Avatar
Default Re: Suggestions for storing car?
In my owners manual under storage section, pages 263-264, it gives some ideas for you to consider. Check your manual for specific pages. It may be different.
Old Nov 4, 2009 | 09:51 PM
Rapps's Avatar
get one of those bubbles
http://www.autotoystore.com/carcapsule.html
CarCapsule: The Ultimate Car Cover
Old Nov 4, 2009 | 11:13 PM
kalway's Avatar
I got an MDM Products Car Pocket 2 years ago and have stored an Intrepid in it for 2 years, now my daughter is 16 and driving it so the Crossfire is in it this winter at the Farm in the shed. It kept the mice, bugs and everything else away from the car. Your drive the car into the bad an zip it shut. It is 24 feet by 16 feet.
Old Dec 12, 2009 | 03:35 PM
Marine05's Avatar
My son who is in the military is going to school for 3 months and has to put his car in storage. He is in California. Besides filling the gas tank and covering the car, does he have to do anything else? He is concerned that he will get flat spots on his tires if the car is not moved. Any advice?
Old Dec 12, 2009 | 03:41 PM
The tires of today do not get flat spots, but alway a good idea to put something under the tires. I use a few pieces of cardboard. Plug the exhaust to avoid rodents from getting in there. A nice snug cover will do as well.
Old Dec 12, 2009 | 04:19 PM
Thirteendog's Avatar
These things are so cool. I want to get one and put some fake snow in with my car. They're the perfect snow globe.
Old Dec 12, 2009 | 05:27 PM
Marine05's Avatar
[quote=FP]The tires of today do not get flat spots, but alway a good idea to put something under the tires. I use a few pieces of cardboard. Plug the exhaust to avoid rodents from getting in there. A nice snug cover will do as well.
Thanks FP!
Old Dec 12, 2009 | 05:29 PM
Marine05's Avatar
Car in a bubble. Pretty neat! Thanks!
Old Dec 13, 2009 | 12:23 AM
Mr. F's Avatar
i got a Car Capsule about a month ago, it'll be nice to have the car already clean when i take it out in the spring.
Old Dec 13, 2009 | 01:17 AM
XF1RE's Avatar
While I drive my Crossfire all year round, I have been storing a Corvette for many winters. I have found that a battery tender is worth its weight in gold- absolutely extends the life of the battery(especially if you don't drive the car that much when the car is out of storage). I will second the motion to fill the tank to prevent condensation forming in the gas tank and add that it is a smart idea to put STABIL(spelling?) or some other fuel stabilizer(dealer suggested I do this after I had to replace some of the car's fuel system and no problems since). Finally, to help prevent flat spots I park the car on a large piece of carpet(to soften the concrete). Whether or not it makes a lot of difference in the tires- it definitely looks cool to park your car on carpet! Good luck
Old Dec 13, 2009 | 09:31 AM
If you drive it about 50-80 miles every other week do you need fuel stabilizers?
Old Dec 13, 2009 | 11:14 AM
sonoronos's Avatar
Use a battery tender or simply disconnect the battery altogether.
I stored my XF for 12 months and left the battery connected - the battery went totally dead and I had to get a new one @ $80.00.
Not sure what to put on the floor, but I think critters are going to be a much larger problem than moisture.
Old Dec 13, 2009 | 12:18 PM
stryfox's Avatar
Sounds silly put put a bar of Irish Spring soap in the interior. It will help keep the pests out.
Old Dec 13, 2009 | 04:50 PM
Mr. F's Avatar
which is exactly why i went with the Car Capsule. i catch a couple mice each winter in the basement, i'm sure there's more than that in and out of the garage and the last thing i want to do is have to have the car rewired or re-upholstered or whatever. plus, the car gets wet if i leave the garage door open while i'm shoveling, or it'll get dusty if i'm cutting up firewood....this prevents those issues also.
Old Dec 13, 2009 | 05:08 PM
I sure hope not. I drive less than that in the roadster year round and don't use it.
Old Dec 14, 2009 | 09:23 AM
But if they do get in there is no excuse for them to be dirty anyway.
Rodents are a pain, I had a chipmunk build a nest behind the headlight in a car I had once, not content with that he decided to get rid of the wiring that ran through his little abode. That was his first mistake, noticing the headlight was out made me aware of his nest. His second mistake was finding new nesting material in one of two garbage cans sitting side by side, one full of leaves and the other empty. All went well I suppose until he forgot which was the full one, I found his body at the bottom of the empty one, too far to jump out.
Old Dec 15, 2009 | 11:17 AM
bibbs's Avatar
Thumbs up Re: Suggestions for storing car?
Put dryer sheets in the engine compartment under the battery and on the opposite side. The criters will nest and chew you wiring.
ingsoc39
Jul 7, 2022 04:25 PM
autumnmass
Jul 2, 2015 10:35 PM
victorlautreamont
Jun 29, 2015 01:51 AM
gobraves423
Jun 6, 2015 07:03 PM
WindRestrictor
Jun 1, 2015 02:31 PM
