Need mathematical help??
Old Jan 25, 2010 | 01:15 PM
Crossfireone's Avatar
Default Need mathematical help??
Always wondered what the parasitic drain is on my Crossfire so since I'm installing a new battery thought I would take reading. I have a volt-ohm meter that has an amp. port so here's what figures I found. My amp reading is 0.05 A. The manual for this meter shows that 1ma = 0.001 ma. It mentions that a typical drain is 100 ma which allows for the clock&radio memory. Is there a formula that would tell me what my 0.05 A reading translates into for a VOLT draw that my car is putting on the battery with the key off & all known draws other than parasitic draw are off, in other words doors closed ,no alarm set, auto lock feature subdued, etc.?? Thank you
Old Jan 25, 2010 | 02:56 PM
Default Re: Need mathematical help??
That fits within specs, nothing to worry about unless you plan to let the car sit for long periods of time (like over winter).
Is there a formula that would tell me what my 0.05 A reading translates into for a VOLT draw that my car is putting on the battery with the key off & all known draws other than parasitic draw are off, in other words doors closed ,no alarm set, auto lock feature subdued, etc.?? Thank you[/i]
There is no such thing as "Volt draw". Your current draw is 50 millamps, you are within specifications.
Old Jan 25, 2010 | 03:02 PM
GDC-SRT's Avatar
I believe Pizzaguy is right.
.05A
multiplied by 1000 ( one Milliamp)
Equals 50 milliamps
Old Jan 25, 2010 | 05:03 PM
waldig's Avatar
Talking Re: Need mathematical help??
1ma. or milliampere is 0.001 AMPS. Let say that the battery has 50 amphours of stored current, You could ideally support a 1 ma load for about 50,000 hours. Or Ideally 50 amps for one hour, but the higher the rate of drain the less you can get before the voltage ( Pressure or push) tapers off and falls below like 10 volts and your kaput.
The battery has self discharging characteristics which shorten that by a goodly amount, as a good battery will sit for a couple of months and still crank you up, beyond that your into the lucky region.
Woody
Ralph289
Jul 26, 2015 12:52 PM
onehundred80
17
Jul 24, 2015 06:50 PM
jimmyjet
Nov 3, 2011 09:32 PM
Franc Rauscher
Mar 31, 2010 02:32 PM
Fritz123
Jul 23, 2008 07:19 PM
