water pump bad
Old Feb 2, 2010 | 04:49 PM
askmenomore's Avatar
Default water pump bad
ok my bearing on my water pump is shot. can any one tell me where the belt adjusment is so i can loosin the belt. search pulled up nothin
Old Feb 2, 2010 | 05:18 PM
MikeR's Avatar
Default Re: water pump bad
Look for tensioner pulley. You rotate it counter clockwise and release tension. You will need an E10 socket and make sure it is ALL the way on and seated so it dosent slip off and bugger up the bolt.... have fun with the pump....
Old Feb 2, 2010 | 05:34 PM
crossfirefun's Avatar
This thread has pics and help.
https://www.crossfireforum.org/forum...tensioner.html
Old Feb 3, 2010 | 01:29 AM
You use the term adjustment, I am afraid there is no adjustment. The belt tensioner just adds tension it is not adjustable, if that is your question and I am reading it right. You cannot ease the load on the pulley of the water pump.
Old Feb 3, 2010 | 12:16 PM
apkano's Avatar
Life is random...so am I.
Technically, it's a spring-loaded tensioner. You do like MikeR said and use a E10 socket on a ratchet and counteract the pressure of the spring.......that will allow the serpentine belt to loosen so you can get it off the water pump pulley.
Old Feb 3, 2010 | 12:56 PM
yea thats what i was meaning. thanks for the hlp guys i got it going, thanks for all the help
steps
Oct 13, 2015 06:18 PM
o55ie18
Oct 5, 2015 05:50 PM
Billy22Bob
Sep 28, 2015 08:08 PM
Billy22Bob
Sep 26, 2015 10:16 PM
Selbyl
Sep 26, 2015 04:15 AM
