car keeps cutting off!!!
Old Apr 14, 2010 | 08:29 AM
markenseth's Avatar
Default car keeps cutting off!!!
i have a '04 crossfire. for the last two weeks it has cut off on me four times. sometimes it starts fine. and then sometimes after being driven and i go to crank it up it acts like it doesn't want to start. it stalled out on me at a red light lastnight. but after 5min. or so if fired back up and ran fine. the other day i went to get a bite to eat and it started fine, but when i got done eating and tried to crank it, i had to turn the ignition twice before it started. i just got a battery last year. i'm thinking it's a sensor or something. has anyone else had this problem?
Old Apr 14, 2010 | 08:34 AM
bmorgan's Avatar
Default Re: car keeps cutting off!!!
Defective solder joint on your Relay Control Module. https://www.crossfireforum.org/forum...-no-start.html
Old Apr 14, 2010 | 08:55 AM
maxcichon's Avatar
Try to see if you have any Diagnostic Trouble Codes stored. This also sounds like a faulty Crankshaft Position Sensor.
https://www.crossfireforum.org/forum...on-sensor.html
Maybe, maybe not.
Old Apr 14, 2010 | 09:46 AM
MikeR's Avatar
^^^ I'm with Max since it turns over and just dosent start..... do you have a CEL? The CPS almost always throws an error and lights the CEL....my expierence anyway..
Old Apr 14, 2010 | 11:29 AM
But could it be the Relay Control module (fuel pump relay)????
I'd get a Crankshaft Position sensor and also take the RCM out and look at it per the 'RCM" thread.
Old Apr 14, 2010 | 11:49 AM
bmorgan's Avatar
I'm having dejavu here. I thought that a CPS will always throw a code and almost always it is a P0335. Due to the fact that he is saying that it will generally happen at a red light or after he has been driving for a bit, my money is still on the RCM.
Old Apr 14, 2010 | 12:04 PM
MikeR's Avatar
CPS code is P0335..... I agree, it almost always throws a CEL..(I almost always never say always. Murphy lives in my house)...
Check both and be sure...
Old Apr 14, 2010 | 12:09 PM
apkano's Avatar
Life is random...so am I.
Kick his a$$ for me please!
Old Apr 14, 2010 | 12:14 PM
bmorgan's Avatar
That is what I have in my post. Well, now that I edited it anyway. My fingers must not have done what my brain was telling them to do. LOL
Old Apr 14, 2010 | 01:26 PM
tighed1's Avatar
Question is does the car CRANK when it is dead?
No Crank - RCM
Crank no Fire - crank position sensor
Old Apr 14, 2010 | 01:36 PM
OKC-XFR's Avatar
Mine would start fine when cold, then crank when hot but take a long time to start - the fuel pump was replaced under warranty and I have had no problems starting since.
Old Apr 14, 2010 | 02:51 PM
markenseth's Avatar
thanks guys!
Old Apr 14, 2010 | 02:56 PM
bmorgan's Avatar
No Crank - RCM
Dang.... another case of dejavu. LOL
Old Apr 14, 2010 | 03:30 PM
tighed1's Avatar
I like to call it "DJ" vu.
Get it? de ja vu.
Just sayin'...
Old Apr 14, 2010 | 03:42 PM
bmorgan's Avatar
Get it? de ja vu.
Just sayin'...
LOL, I am going to have to remember that one.
Old Apr 15, 2010 | 04:05 PM
beasticles's Avatar
Surprised no one has mentioned this yet but CHECK YOUR BATTERY! It may either be time for new battery or the connection between the battery cable and the battery terminal could be getting a bad connection. Corrosion on the negative terminals of our batteries is a fairly common problem and corrosion will often times lead to poor connection to the battery.
Definitely worth trying to at least look over the terminals for anything that might be causing a bad connection and if need be cleaning or simply removing and reinstalling the cables to the terminals.
Good luck!
Old Apr 29, 2010 | 09:04 PM
HOT WHEELS's Avatar
Unhappy Re: car keeps cutting off!!!
Crossfire 2004,wont start usually when hot,replaced the cps,still the same,when monitoring the fuel pressure it dropped from 57psi to 11psi and the engine die of course!;Started again everything fine the residual pressure its holding at 30psi after 2 hours. Which could be the problem the fuel pump, the relay or something else?
Also check the relay with a magnify glass ,all of them shiny like new.
After 3hours the residual pressure dropped to 20psi,turned the key to run position the pump did not kicked in, did this a few times and got the pump to work pressure went to 57psi,fired the engine then the pressure dropped again in a few seconds. Did this a few more times until the engine kept going,turned it off. Tomorrow I'll keep troubleshooting. All advices are welcome.
Old Apr 30, 2010 | 12:54 PM
tighed1's Avatar
If you have a soldering iron reheat the three joints on the RCM.
Old May 1, 2010 | 01:24 AM
HOT WHEELS's Avatar
Thanks tighed1 ,will try that tomorrow!
Old May 4, 2010 | 02:13 AM
jerry rosewicz's Avatar
With no check engine lights, it sounds like it is not a bad Camshaft or Crankshaft sensor.Keep looking for the other suggested things to check.
