Signal Light Flasher Location
Old May 25, 2010 | 01:46 PM
Cydetrak's Avatar
Default Signal Light Flasher Location
Does anyone know where the Turning indicator Flasher is located?
I'm swapping mine out with one for my LED indicator bulbs, but for the life of me cannot locate it.
Thanks!
Sean
Old May 25, 2010 | 02:37 PM
robby363's Avatar
Default Re: Signal Light Flasher Location
I think it's built into the multi-function switch. Which means there's not much you can do.
Old May 25, 2010 | 07:49 PM
Thanks!
Sean
robby 363 is correct, if you follow the instructions in the shop manual it ends up telling you to replace the M/Function switch - ouch.
Old May 25, 2010 | 11:44 PM
Cydetrak's Avatar
Thanks for the quick replies.
Do you know of any way to add a load resistor on the front indicator bulbs to allow for LED use?
Thanks!
PNA
Nov 12, 2020 04:44 PM
Vazgen
Aug 11, 2015 01:24 PM
axnguyen
Jul 21, 2015 11:41 AM
Adrian_X
Jul 12, 2015 11:05 PM
joethejeweler
Jul 7, 2015 08:58 PM
