Bad Day in Nashville, TN.
Re: Bad Day in Nashville TN
Originally Posted by Osofast2
Time for a V8 Drop !!!! you know you want to do it !
I am reminded of the XKE and XJS Jags with V12's or Inline Sixes.
The inline six was a far better handling car and much more reliable than the self destructing, rather incindery, V12's. I drove both in the 70's and 80's as my business partner was a Jag fanatic and a collector. He still has a fleet of them.
I like the six in our car. So if I can, I'm staying there. I love telling losers at the stop light, "you just got you butt kicked by a six."
Now, if Allstate insists on going total, I'm open to suggestions.
franc
Franc, sad to hear. That's one reason I stay high and dry with my CAI. Here's something you may want to check out
Chrysler Crossfire PArts CAR
Don't know if it has an engine or not.
John P
FTC
John P
FTC
Franc ... met you down at the CAA and you were most hospitable in opening your factory for us. We all appreciated that and enjoyed your hospitality. Now..to the point.
About 12 yrs ago I owned and lived aboard a 40 ft trawler style boat for 3 yrs, and during that time the sea water exchanger sprung a leak and hydrolocked the diesel engine. I had a diesel mechanic check it out and after "pickeling" the engine with WD40, and installing a new exchanger, engine was fine. I don't know about our 6 cyl, but you might try considering this ....
1) see if you can hand crank the engine to see if its not totally locked up. If it is forget the rest because then I don't know....
2) remove the heads and drain the oil
3) pour WD40 into the cylinders and work the cylinders by hand cranking the engine letting the WD40 displace water. This might have to be done numerous times over a course of a few days, not letting the cylinders dry out. I used almost a gallon of WD40 over 2 weeks while my part was being shipped. You may not have to do it for that long.
4) Drain the oil pan occasionally of the collected "mixture"
5) After sufficient "pickeling" (take a guess on what is sufficient), fill with oil and crank engine, preferably without starting, or by hand, to disperse the oil back to the cylinders
6) refill engine with oil and drain again after cranking again
7) refill engine again with oil and start engine and pray.....
Like I said this got my diesel engine back like new, and I'm sure there are people here on the forum that will either put a thumbs down on this, or say it could be a good try to save the engine. Just my $.02
Good luck ..... Howard
edit.... of course at some point you have to replace the heads .... DUH
Curious idea but, no. I will likely stay original with the NA if I can. I like the light nimbleness of the high torque six.
franc
franc
What is weird is that it runs. it just has no torque. One cylinder is dead and one is intermittent. Frankly it sounds more like a plugged cat converter than anything.
Except that I have two funky cylinders. #3 has no compression.
It all seemed to clear when I was driving it to the dealer. But then lost power. It ran but no torque.
They get into the engine next week and I will be there to see.
Then I will decide what to do.
I think at worst I bent a rod or perhaps flattened a cam. Dropped a valve?
These aren't interference engines so a dropped valve wouldn't ruin the engine but could cause these symptoms.
Unless the block is damaged, I will rebuild it.
Again, I still have questions about hydro lock as the engine ran fine for more than an hour after the rain. I have driven in worse weather without issues and besides, I have over 20k on this CAI since I solved the insignificant "water in the intake" problem back in 2008.
It will be a saga. Just want to get it done before the fall Dragon.
franc
Originally Posted by patpur
My Needswings (airfilters) are in front of the radiator, behind the grill. I think there is one is it TVT? that dumps into a wheel well. I was a bit concerned driving up to Carlisle in heavy rain last weekend but I had no problem what so ever. When all is said and done its probably a lot like the stock intake. They are just open tubes on either side of the radiator that eventually lead to your filters etc. The Needswings is Filter and then tubes etc. Just a bit bigger and meaner and louder. Franc sorry to hear about your mishap, hope it all works out.
Pat
Pat
K&N DryCharger filter cover
All things considered, I am not sure if Franc's are set up this way, but when I see the filters RIGHT behind the grill, it makes me worry....
Pat, when I was putting together my CAI, I thought long and hard about putting the filters up front like the NW. I LOVE the look, especially with the aftermarket mesh grille, but the more I thought about it, I didn't like the idea of trying to suck air through something wet everytime it rains (mine is a DD). We all know the flow rate goes in the toilet when these things get wet, hell they even sell a cover for them for this reason:
Unless the hatch door is missing, very little water enters this box, if at all. I have driven thru deep puddles with no issues since I lifted the filter off the floor of the wellbox.
After the filter is a 3.0" inch pipe, a 90 elbow and then a 16 inch rise to the top of my engine bay. To bring a columm of water up that 3.0" pipe would require that my intake is virtualy submerged. It then goes horizontal for 24 inches before entering the MAF module.
So while an occasional wispy spurt of spray is possible into the MAS unit, a full load is unlikely.
Also, during the original designing, when I did have some water in the intake, I got an engine light and some roughness from the engine. The MAS was detecting wrong because it was "damp" not flooded. But nothing like this.
I always felt that water taken in the intake would quash the engine in a heartbeat. So how did this happen an hour later some 80 miles away from the water I encountered?
Personaly, I think the Chrysler Certified Mechanic Technichian saw the custom low level intake CAI and presumed.
We'll see when we get inside!
Originally Posted by rush549
Dang Franc, sorry to hear about that. It seems many here are getting some hard luck lately. A couple of years ago I ran though some really heavy rain, heavy enough that I couldn't see. The toughguy side got ahold of me and I refused to pull over. I ended up going though some pretty deep stuff for a car this low. I never thought in a million years about hydrolocking her though. I sure will now though. Though given my luck as of late, I wouldn't be surprised if that weren't next on my list. Someone will probably come along and fill my newports engine with gravy or something. If anything, we can always say that at least you didn't just drive your Buggati Veyron into a lagoon, or spin your 300k polished Cobra and land upside down in a creek.
Take care of that Newport man. Those late 60's Mopars are special. That one you have is one of my favorites.
franc
sorry to hear about this Franc....doesn't sound like hydro lock to me at all...it ran too long for that to have happened...it might have let water in, causing damage as you drove, but not hydro lock...good luck either way my friend....I know you will save it...
I just got off the phone with the service manager in Nashville.
It was not Hydro lock.
YES!
A valve dropped on cylinder three and caused the timing to shift slightly. Explains all symptoms.
I believe I called it last week when I posted.
Post #25
"These aren't interference engines so a dropped valve wouldn't ruin the engine but could cause these symptoms."
Other than the bent/stuck valve no damage to the engine.
They are going to replace all the valves and guides, seals and gaskets involved, and hopefully I will have essentialy a top overhauled original engine and my Crossie back in a few weeks.
In time for the Gateway trip to Merimac Caverns and the Dragon.
Hurray!
soon to again be,
THE
roadster with a stick
YES!
Post #25
Hurray!
soon to again be,
THE
Originally Posted by Chris L.
So did H2O cause the problem or was it totally unrelated?
If the insurance adjuster says it is water related, I'm not arguing with him. Not because I would be dishonest but my analysis would be and Opinion.
Many will tell you, my opinion ain't worth much.
However, between you guys and me, I seriously doubt water did it.
on
Franc,
If I remember correctly, the MB that self-destructed on MB-World traced its initial failure back to a dropped valve.
Only difference was, this one DID hit the piston. BLAMMO.
Any chance you will be able to inspect the old valve?
Odd that you would both drop a valve, with the huge spread in mileage (his had over 100K)
Cheers
Cheers
Last edited by JHM2K; 07-26-2010 at 05:23 PM. Reason: Mis-informed about certain details
What RPM level was your rev-limiter reset to?
5800 in 4th fifth and sixth
I assure you I was in 5th or 6th during most ofmy trip through the rain.
As I came off I-65 in Franklin TN I did downshift the very long gentle ramp. Drove one block to the Hotel. I raced no one on that short trip.
That said, I have occasionaly hit the rev limit of 6300 during street manouveres. But I don't drag race, on or off the street.
Glad they found the problem Franc, see you soon!
