air filter/ fuel filter replacement
Re: air filter/ fuel filter replacement
Originally Posted by bluemax
please advise location of the air & fuel filters , difficult to replace,
TX
TX
The air filters are located in the engine cover. Disconnect the air hoses by pulling them towards the front of the car, then pull the engine cover off back to front. NEVER the other way. Flip the engine cover over and locate the Torx screws on both sides. The air filters are under those covers. Remember to insert and seat them correctly. Refer to the old ones if you don't know. When putting the engine cover back on, seat it first then push down. Look for the rubber ****-looking things for where the clips go. The one clip on the front of the engine cover goes on a metal rod towards the front of the engine instead of a **** like the others. It should go on correctly if you seat the others correctly.
Also, remember the search function is your friend.
EDIT: Remember to clean out the air boxes when you take the old air filters out and keep the new ones clean. Anything that goes down the intake past the air filters goes straight into your engine.
Yo Blue.
Go here HERE and download the service manuals. EVERYTHING you ever wanted to know about the car is there. If it's not just ask us and we'll be here to help ya! Isn't this a great forum!?
Fuel filter is located by the passenger rear tire area protected by a plastic shield. Air filter location where shapeshifter309 sed.
BTW. Did ya ever figure out your spoiler problem?
on
Originally Posted by shapeshifter309
Well, the fuel filter is somewhere by the right rear brake, or so I've heard. Someone else will have to fill you in on that.
Kodebuster
11-05-2020 04:06 PM
07-24-2015 07:57 PM
ja.nko
07-10-2015 03:21 PM
