Problem with Crossfire Turning off
Old Sep 5, 2010 | 10:30 AM
Deee's Avatar
Default Problem with Crossfire Turning off
I Have been having this problem with my Crossfire for a while now. It can turn of mid-drive, the engine shuts off and I lose power steering but the ac and radio and everything still works. It usually happens when Im stopped at a light or after I stop by the store and get back in my car it wont start.
I thought it was the crank shaft sensor so i replaced it a week ago but then it happened again last night.
The problem seems to be another sensor since I can start the car after about 30 min of letting it cool down.
I appreciate any help I can get on this subject matter.
Old Sep 5, 2010 | 10:56 AM
Default Re: Problem with Crossfire Turning off
relay control module ...there is a sticky for this, and tighed1 has the fix...so pm tighed1, or look up "mystery not start, relay control module"....good luck
Old Sep 5, 2010 | 11:34 AM
Deee's Avatar
thanks a lot man ill look into it
Old Sep 5, 2010 | 12:37 PM
kingkub57's Avatar
Does it crank over but does not start? or does it not crank at all when this happens? also can you hear the fuel pump engaging when you turn the ignition on when this happens as well? just a couple more things for ya to check, let us know.
Old Sep 5, 2010 | 05:58 PM
Deee's Avatar
it doesnt crank, when I turn the key Its almost like a little zapping short circuit noise. the engine wont turn over but everything else turns on.
Old Sep 5, 2010 | 06:10 PM
kingkub57's Avatar
Then check into doc's post and tighed1's repair for the RCM, this could be your problem, also how old is your battery, if it's original it might need replacing as well since these cars are sensitive to low battery voltage.
Old Sep 5, 2010 | 09:24 PM
Deee's Avatar
its a 3 month old battery and new alternator. Battery and every thing is fine. My mechanic plugged the computer into it and couldnt find a problem when the car ran fine and the engine turned. This problem happens to me like once a week.
Old Sep 6, 2010 | 01:04 AM
tighed1's Avatar
That would be yer RCM as mentioned.
Repair is HERE.
Or send it to me and I'll fix it.
And hey, WELCOME to the Forum!
DJ (Deee Jay)
PS - yer name is only half as cool as mine!
Old Sep 6, 2010 | 04:33 AM
Deee's Avatar
Thanks a lot i appreciate it now I at least know the problem.
I would take it to you if you are located anywhere near central florida.
Im scared to take my car to far
Old Sep 6, 2010 | 08:32 AM
32krazy!'s Avatar
if you pm tighed (aka DJ!) he can tell you about his rcm fix. he now has a spare and send you the spare and you send him your broken rcm which becomes the next "spare". its a great system he has worked out!
Old Sep 13, 2010 | 08:53 AM
BP11's Avatar
I have just started to get the same problem mentioned by the OP. I will send my RCM out when I put her away for the season it has only shut off twice since owning her and it did the no start thing once. I am really glad to know it's probably not something outrageously expensive.
Old Nov 5, 2010 | 01:11 PM
Deborah Walker's Avatar
My car is shuttering, like it wants to shut off, then when I press the gas pedal it hesitates, almost like it is not getting fuel, or maybe a bad batch of fuel???
Help
Old Nov 5, 2010 | 01:28 PM
And no check engine light Deb?
Old Nov 5, 2010 | 01:31 PM
Nope, no check engine light.
Old Nov 5, 2010 | 02:34 PM
Help
Sounds like a bad batch of fuel, or maybe time for a new fuel filter??
Old Nov 5, 2010 | 02:47 PM
I was thinking bad fuel, too.
Probably that damn "Sam's Club" gas...
Old Nov 5, 2010 | 02:51 PM
Germany's Avatar
Had that problem some time back.
Add some fuel injector cleaner in it from Lucas Oil's. Best on the market. Mine stopped stuttering after just 3 miles when I put the cleaner into the tank.
Give it a shot.......
Old Nov 5, 2010 | 02:52 PM
Is my thoughts as well. 38K on the clock am I due for a fuel filter??
Old Nov 5, 2010 | 03:02 PM
Germany's Avatar
Yeah, 38k is a bit early for a new fuel filter. Or have you been using a fuel/sand combination?? lol
As already said, try the injector cleaner for a start. its only 6 bucks or so.........
Old Nov 5, 2010 | 03:06 PM
Do they carry that at any parts store??
