The Correct Way to Close The Cupholder !!!
Old Nov 15, 2010 | 06:29 AM
Chris L.'s Avatar
Default The Correct Way to Close The Cupholder !!!
Pinch the rear top part using your right thumb and forefinger. (Your thumb will be inside the holder area, and your forefinger will be against the silver portion.) As you pinch this section together, gently fold the cupholder down into the closed position.
From a post by Morlie822.
Old Nov 15, 2010 | 09:16 AM
Mike1118's Avatar
Default Re: The Correct Way to Close The Cupholder !!!
I just use a short piece of two by four and an eight pound sledge hammer. Works for me.
Old Nov 15, 2010 | 10:38 AM
former NXMX5's Avatar
Welcome to the forum.
Old Dec 1, 2010 | 03:47 PM
RonDace's Avatar
I've been applying a small pressure in the rearward direction to the front part of the holder then pushing the back of the holder forward/down. This has been working fine for me. I started doing this about five years ago because I never liked forcing the holder closed. There was always this 'click' that I had to push through until I started the method I am now using.
Old Dec 1, 2010 | 04:02 PM
Works this way for me too.
Old Dec 1, 2010 | 04:56 PM
we have a cupholder?......
Old Dec 1, 2010 | 05:35 PM
Chris L.'s Avatar
Two cupholders,
Old Dec 1, 2010 | 07:14 PM
PNA's Avatar
PNA
Works for me too. Figured that one out before I bought the car. I knew forcing it -- that it would only be a matter of time before it broke.
Old Dec 3, 2010 | 01:52 PM
Vegaslegal's Avatar
Pinch the rear top part using your right thumb and forefinger. (Your thumb will be inside the holder area, and your forefinger will be against the silver portion.) As you pinch this section together, wrap the balance of your fist around the rest of the cupholder. Place second hand around first and also grasp open cupholder (now with two fists). Get on your knees on the passenger seat and twist and lift with all your might until the useless coffee ejector disengages entirely from the counsel. Discard item in your hand. Use gaping hole in counsel to store something useful, or stuff a Beany Baby in same for laughs.
Old Dec 3, 2010 | 02:14 PM
corfire's Avatar
My theory is, if you don't open it, you don't need to close it!
Old Dec 6, 2010 | 09:28 PM
milkjuggz's Avatar
That's what I thought too when for some reason I got in one day and noticed something hitting my elbow...
I think the first time I used it, the "fangs" penetrated the styrofoam coffee cup, promptly spewing scalding coffee all over my alcantara seats.
Old Dec 7, 2010 | 09:43 AM
Larry Hitze's Avatar
Vegas you have a good plan, If you ever took one off and saw for yourself how small the catch is you would be amazed that it lasted as long as the do.
Old Dec 8, 2010 | 08:10 AM
vpats's Avatar
Mike1118, I like your style now I feel like a wimp because I only use one of them rubber mallots. Now about that ash tray....
Old Mar 20, 2011 | 11:54 AM
drivergirl1030's Avatar
I just bought velcro tape and now I can open and close it without any problems. Oh it was broken when I bought it.
Old Mar 20, 2011 | 12:12 PM
Mike-in-Orange's Avatar
Have to say I also agree with RonDace on this. That little bit of pressure beyond vertical allows you to easily close it. It's really sort of a reverse of opening the thing where you push it a bit farther into the opening in order to make it pop open. Honestly, I've never had a problem with my cup holder, whether holding a bottle of water, my stainless steel travel mug or even a Starbucks Venti Latte.
Old Mar 20, 2011 | 12:47 PM
LantanaTX's Avatar
This is the only cup holder I have ever had that makes me want to use my fist! Just yesterday I was parked next to a SLK with its top down and I stared at its upper dash wondering if it could be used on the Crossfire. It has a cup holder that holds two cups that slides out of the dash.
Old Mar 20, 2011 | 01:35 PM
Beener has done that. He might have photos of it in his gallery.
Old Mar 20, 2011 | 09:10 PM
HowardJ's Avatar
I forgot to close it once, got back in the car, and elbowed it. It popped out, spring went flying and the cup holder landed in the passenger seat.
never cared to fix it. I don't used it.. only that one time. go figure.
Old Mar 20, 2011 | 09:34 PM
SparkieSRT6's Avatar
SSB SRT6 405hp/401Tq
If you push down on the small black springloaded cupgrabber piece that is attached to the underside of the complete cupholder cover, the whole assembly collapses and drops down into the armrest very easily.
Old Mar 20, 2011 | 09:50 PM
Beaner's Avatar
TA DA. Fits well in my auto, coupe. Ohh and before anyone says anything about the siver lighter, it has been replaced with a black one from a base coupe.
