fan only works with a/c
Old Dec 3, 2010 | 10:25 PM
GNSVO's Avatar
Default fan only works with a/c
I ASSume this points to the module as being the culpret? I ran the car in the garage until temp was up over middle slash, and still no fan. Turned on a/c and fan kicked on(low speed). Any input would be appreciated. Called Chrysler, module was $$$
Ross
Old Dec 4, 2010 | 08:39 PM
blackcrossfire07's Avatar
Default Re: fan only works with a/c
I had this problem twice in 5+ years and had it fixed both times. A common problem in the crossfire. My symptoms were a little different. The fan speed setting was all messed up. It was supposed to be on but wasn't. Then it would just turn on for a few seconds when the switch was off. I forget what the dealership replaced. Either the module or switch... or both. I know it is a very expensive fix because the part is expensive. Both times for me were under warranty.
hhr hellshotrod
Aug 17, 2015 11:27 PM
BrenLW
Aug 4, 2015 01:29 PM
waldig
Jul 15, 2015 02:05 PM
joethejeweler
Jul 7, 2015 08:58 PM
