car died in traffic, please help...
Old Feb 25, 2011 | 07:41 AM
ssdark1's Avatar
Default Re: car died in traffic, please help...
Originally Posted by GDC-SRT
Here is the fix, If you can solder the cost is low.
Or you can contact tighed1, and do the swap with him. Cost, still low.
https://www.crossfireforum.org/forum...-no-start.html
awesome - thanks
Old Feb 25, 2011 | 08:23 AM
tunaglove's Avatar
The real problem is your coroded battery post connection.
Old Feb 25, 2011 | 11:03 AM
GDC-SRT's Avatar
Tunaglove may be correct,
Check the obvious first, that may do it.
At least you now have the RCM repair for your records.
And thank all who figured the RCM thing out, I only posted what they did.
Old Feb 25, 2011 | 11:25 AM
tunaglove's Avatar
Yup, the RCM re-solder is one of the first things I did when I got the car and is also good advice. Good luck!
Old Feb 25, 2011 | 12:49 PM
Sennaspirit's Avatar
Since you brought this up, I should post that in the last year, my xf has stalled twice and failed to start once. All three times it was wet out side. The stallings occur while waiting for lights in active rain and post storm wet conditions. The failure to start was after a massive storm while I was at work, car was parked in the open and and i could not get it to start at all. After about an hour it just fired up. It did not crank on any of the three occasions, turn of the key and no crank. the episode was about 6 months ago. It seems logical that its a moisture issue but not sure at all. Anyone else have similar experiences?
Old Feb 25, 2011 | 03:15 PM
Bladecutter's Avatar
That's the main clue as to the cause of the issue.
If you turn the key, and the car doesn't crank, then its the solder issue in the RCM.
If the engine does crank, but never fires up, then its most likely the Crankshaft position Sensor (CPS).
BC.
mhajek18
Dec 30, 2015 03:40 PM
mhajek18
Jun 17, 2015 01:35 PM
IGot2P
Jun 11, 2015 11:05 AM
gobraves423
Jun 6, 2015 07:03 PM
mouserider
Jul 20, 2003 03:42 AM
