Painted Moldings
Old Mar 3, 2011 | 01:27 PM
xyz2424's Avatar
Default Painted Moldings
Have other Crossfire owners had an issue with paint showing sign of wear on the aluminum moldings (I believe they are aluminum?) that run between the door and roof of the car?
The body shop estimate to repaint both moldings was $200.00. Does that sound about right?
Thank you for any responses.
Old Mar 3, 2011 | 02:02 PM
AllEuro's Avatar
Default Re: Painted Moldings
Originally Posted by xyz2424
Have other Crossfire owners had an issue with paint showing sign of wear on the alluminum moldings (I believe they are alluminum?) that run between the door and roof of the car?
Are you referring to the silver painted pieces surrounding the windshield. I'm not sure I understand the part you're looking for. The only aluminum I know of in the area you're referring to are the sill plates and the inside door handle. Everything else is painted black or silver, depending on the location.
Old Mar 3, 2011 | 02:08 PM
xyz2424's Avatar
I'm referring to the long 3/4" painted strip that runs above the doors. In searching old threads, I found that a few others have had the same problem. I need to have them fixed. I'm mostly curious about cost (if anyone else has had the work done), and whether it would be better to have them repainted or purchase new moldings and have those installed.
Old Mar 3, 2011 | 02:14 PM
AllEuro's Avatar
So the rubber seal? I know those can get pretty ratty looking with time, if that's what you're referring to. If it is, then I am of no help, sorry!
Old Mar 3, 2011 | 02:41 PM
texas t's Avatar
Are these the 2 strips on the roof Danny
Old Mar 3, 2011 | 03:34 PM
jlindsey86's Avatar
I know what you are talking about. $200 is probably about right, if not a little high.
Old Mar 3, 2011 | 03:47 PM
Here is a thread about these strips unless I am mistaken.
https://www.crossfireforum.org/forum...dy-panels.html
Old Mar 3, 2011 | 06:25 PM
xyz2424's Avatar
Thanks for the link to the old post... very helpful.
mopar1969
Aug 6, 2016 02:21 PM
ATX SRT-6
Oct 12, 2015 03:16 AM
maxcichon
Sep 25, 2015 02:55 PM
ozkancab
Sep 25, 2015 10:55 AM
XFIRED-TX
Aug 8, 2015 07:38 PM
