TPMS Leaking?
Old Apr 10, 2011 | 01:47 PM
themush1326's Avatar
Default TPMS Leaking?
I went to swap out my winter tires for summer ones and I asked the tech to look at a leak I have on one of the rears.
Its really slow and most noticeable when you put air in and relaease the nozzle it will hiss
push the pin around stops it but still leaks slowly.
The tech informed me the sensor is leaking and needs to be replace is this possible?
They wanted 70$ installed for the new sensor.
been going there for years and they are pretty honest as far as I can tell.
Old Apr 10, 2011 | 02:00 PM
Default Re: TPMS Leaking?
yes sir, it is possible, and is possible it was damaged at install, so watch them when they are mounting your tires....
Old Apr 10, 2011 | 05:42 PM
and now the TPMS light wont go out, they werent able to reset it
Any alternatives other then going to the dealer
Old Apr 10, 2011 | 06:24 PM
they have a battery in them. All the dealer will do is offer to sell you a new one. My light is on in both cars, I just got use to it. It really serves no function, other than letting you know the tire pressure isn't quite right. You can do this yourself, or spend the money for a new sensor...choice is yours. I check my tire regularly, so TPMS isn't all that important to me...
Old Apr 10, 2011 | 06:55 PM
The shop replaced the sensor but the light wont go out
Old Apr 10, 2011 | 07:22 PM
bluecoupe's Avatar
The new sensor needs to be programed to the monitor. Dealer can do it, if your handy there is I believe a thread on here that talks about using a magnet to program the sensor
Old Apr 10, 2011 | 07:33 PM
they couldn't reprogram it...then you are stuck with the dealer, and hopefully it was just the one sensor and not more....
Old Apr 10, 2011 | 08:05 PM
magneticred's Avatar
If I'm not mistaken, you need to go to the dealer (or someone who has a DRBIII programing device).
Old Apr 11, 2011 | 07:11 AM
Ed Mahoney's Avatar
Ive heard some tire shops rebuild them ??? What do they do I have no clue !!!
Old Apr 11, 2011 | 09:02 AM
I think you have been conned.
The sensor consists of two assemblies, the sensor itself and the stem. The stem assembly comes as a rebuild kit and should be replaced when the unit is put in another rim. That's just a safety as yanking the stem through the hole, out of one and into the other, might damage it.
Also it sounds like it could have been just the valve itself a 25 cent item.
If the unit cannot be programmed it may have been damaged as mentioned above.
The Crossfire sensors are two types, one uses a magnet and the other does not.
It is possible that they have installed the wrong sensor.
O'Reilly and Schrader list two different OEM part numbers, for years '04, '06 to '08, to be replaced by Schrader part#20028 they are 52088990AC and 5096808AA. The '05 and SRT6 OEM part is #5142340AA, Schrader part #20066
TPMS Assembly it is missing rubber Rim Seal. This is not a Crossfire part.
TPMS Rebuild Kit (Not for Crossfire)
Certain Corvette sensors are able to be opened and have the battery replaced. There are many how to's on this on the web.
I am sure that the others probably can be fixed as well, after all how hard can it be?
Old Apr 12, 2011 | 06:51 AM
Can a sensor leak and under what scenario should it be replaced(besides rim swap)
Old Apr 12, 2011 | 09:21 AM
Any leaks will only be from the Schrader valve or the rubber molded part that fits in the rim. The rubber part that fits in the rim is a separate part from the sensor itself.
They are snapped together and held with the nut. See the repair kit in post#10.
minimayhem
16
Aug 23, 2016 07:47 AM
debradegiovanni
Sep 27, 2015 09:39 AM
RacerXofFL
Sep 15, 2015 05:00 PM
caseydeankopp
Sep 13, 2015 07:25 PM
williammt
Sep 6, 2015 11:23 AM
